" /> LFMT configuration - Genesys CTI User Forum
Author Topic: LFMT configuration  (Read 2625 times)
Offline roronoa
LFMT configuration
« on: January 05, 2016, 06:15:21 AM »
Hi
I am currently installing LFMT . I am able to see all the applications  in GAX LFM tool menu like manage log collection, setup indec...
But I am unable to start indexer and rsync, i am getting below error in
[b]ERROR: com.genesyslab.lfm.config.Cfg2FileList - Incorrect number of arguments.The program requires the lfm application, host, port, username, password and the default application (in that order) for the LFM application to generate LST files for all configuration servers. In addition, you can provide a configuration
servername and the list of log files for which the LST files are to be generated.[/b]
[b][IndexerMain] ERROR Incorrect number of arguments. The program requires the lfm application, host, port, username, password and the default application (in that order) for the LFM application to generate LST files for all configuration servers. In addition, you can provide a configuration servername and the list of log files for which the LST files are to be generated.[/b]
I am not able to find any above configaration details in LFMT deployment guide.
« Last Edit: January 05, 2016, 06:24:37 AM by roronoa »
Re: LFMT configuration
« Reply #1 on: January 05, 2016, 08:43:43 AM »
Try to check your startup command arguments for LFMT as is stated within mentioned stack trace/error message
