" /> Call UUID as primary key in master table - Genesys CTI User Forum
Author Topic: Call UUID as primary key in master table  (Read 3642 times)
Offline Prithy
« on: January 06, 2016, 10:22:55 AM »
Hi all,
Could we use the Genesys system variable - CallUUID as the primary key for logging in our DB.
Are there any limitations of using the same.
Please share.
Re: Call UUID as primary key in master table
« Reply #1 on: January 06, 2016, 01:21:35 PM »
It depends on what you want to log into database. CallUUID is a unique key for interaction, but interaction might have several parts, so in case where you will store all parts as separated row/record, the CallUUID will not be unique for this.
Offline Prithy
« Reply #2 on: January 07, 2016, 11:10:34 AM »
Hi Kubig,
We wanted to log the CallUUID as a unique key for a customer inbound call. Could you please also help us in the length of the CallUUID to allocate the field length in the table.
« Reply #3 on: January 07, 2016, 12:08:20 PM »
varchar2(50 char) is enough for this type of data
Offline Prithy
« Reply #4 on: January 07, 2016, 12:22:45 PM »
Many Thanks to you ..
