" /> Updating Agent Wrap Up using GA or GAX via Agent Import? - Genesys CTI User Forum
Author Topic: Updating Agent Wrap Up using GA or GAX via Agent Import?  (Read 2069 times)
Offline pinguin
« on: January 19, 2016, 07:06:27 AM »
Hi All,
I've been using CME (Configuration Manager) to edit Agent properties and I am now beginning to learn how to do tasks in GA and GAX.
I'm wondering if there is a way to use Agent Import to change the Wrap Up Time for a list of Agents, rather than having to search for, open, and edit each Agent individually?
I've tried a file with the pattern:
"User Name","Switch Name","Agent Login","Wrap Up Time"
...but this tells me that the Agent Login is already assigned, even though it is assigned to the Agent I am attempting to update.
Many thanks,
pinguin
Offline enrique
Re: Updating Agent Wrap Up using GA or GAX via Agent Import?
« Reply #1 on: February 05, 2016, 11:03:54 PM »
You can use the manage annex feature on the right hand side of GA. Comes handy for mass updating. You can also use the java api.
