" /> CCPulse Historical View - Genesys CTI User Forum
Author Topic: CCPulse Historical View  (Read 3378 times)
Offline Vishwasam
« on: January 19, 2016, 07:51:53 AM »
I am working on CCpulse+ for our lab environment. I am able to generate Real-time reporting but not historical reporting. Historical reporting is not highlighted.
Even the database connection in CCpuse is offline. Although I added connections to ODS and Datamart.
Let me know for any corrections
Re: CCPulse Historical View
« Reply #1 on: January 19, 2016, 07:58:24 AM »
Set connection to the database, it means to the properly DAP object (all you can find in documentation)
Offline Vishwasam
« Reply #2 on: January 19, 2016, 02:59:27 PM »
Thanks Kubig.  I will check the DAP but is it necessary for the Datamart DB to be in JDBC instead of ODBC database connection ?
« Reply #3 on: January 19, 2016, 03:58:00 PM »
You can use the JDBC DAP
« Reply #4 on: January 19, 2016, 03:59:39 PM »
Ccpulse needs a dbserver and a dap. Then you add this dap to Etl to its connection tab
Don't add more than one dap never
