" /> Chat is not routed to available agents - Genesys CTI User Forum
Author Topic: Chat is not routed to available agents  (Read 4172 times)
Offline novembersaint
« on: January 26, 2016, 06:07:56 AM »
Hello Friends,
What could be the cause for a situation where you have chats in queue and agents in ready state, still stats are not being routed to agents. How to troubleshoot these issues?
Can you please help?
Regards,
KS
Re: Chat is not routed to available agents
« Reply #1 on: January 26, 2016, 08:20:23 AM »
This can be caused by many reason:
[list]
[li]capacity rules[/li]
[li]incorrect configuration[/li]
[li]incorrect agent state[/li]
[li]issue on statserver[/li]
[li]etc.[/li]
[/list]
you have to check the URS,IXN and CHAT server logs to find out, where is the root-cause.
« Reply #2 on: January 26, 2016, 10:03:13 AM »
Thanks Kubig for your reply.
In such cases, how can we get the interaction id ? Do we have to check in stat server?
Sent from my GT-N7100 using Tapatalk
« Reply #3 on: January 26, 2016, 01:47:09 PM »
Agent can be a on non-routable status.
Check on what status they are. I had a scenario where they had 2 DNs on a Place and because 1 was OutOfService their status is OutOfServer as well. Had to remove that 2nd DN.
No magic, just follow URS logs
Offline pablocaamano
« Reply #4 on: January 26, 2016, 08:11:02 PM »
First you have to check if the interactions are being routed and are waiting for an available agent, I suggest to use Trace On/Trace View of IRD. In case you can see interactions waiting for and agent (in target block).
You should check with any monitoring tool (CCPulse), the agent status. You could also check agent state in statserver logs, you should see agent capacity, media state, and current number of interactions handling.
Regards.
« Reply #5 on: January 27, 2016, 11:41:13 AM »
Thanks Cav and Pablo for the resonse.
I do not have access to IRD. Probably ill check the statserver logs if.
Offline n3vek7
    • ITKB
« Reply #6 on: January 27, 2016, 06:22:56 PM »
Additionnal info :
If you don't see the chat session in URS logs, make sure the ixn queue have a strategy loaded to target your agents.
You can see that in IRD (in the Business Process) or in IXN Server Logs (with Myzimir tool if you can))
As suggested by Kubig, check the logs (chat, ixn and urs, in that order.)
Let us know your findings.
Cheers
« Reply #7 on: January 30, 2016, 11:34:45 AM »
Thanks n3vek7. I do not have acceas to IRD. Will have to work on this incident next week. Will keep u posted about the findings.
Offline a.jay
« Reply #8 on: February 02, 2016, 09:41:53 AM »
It can be silly, but could you check in Business Process is it activated strategy or not ?
« Reply #9 on: February 02, 2016, 10:33:42 AM »
[quote]It can be silly, but could you check in Business Process is it activated strategy or not ? [/quote] Without access to the IRD will be hard to check it :)
Offline a.jay
« Reply #10 on: February 02, 2016, 03:34:47 PM »
Kubig, of course, it for future
