" /> Composer 8.1.4 - Voice application and transaction list values - Genesys CTI User Forum
Author Topic: Composer 8.1.4 - Voice application and transaction list values  (Read 2715 times)
Offline ymattica
« on: February 05, 2016, 10:14:48 AM »
there is a way to directly read the values of a transaction list of the configuration db server?
Regards
Re: Composer 8.1.4 - Voice application and transaction list values
« Reply #1 on: February 05, 2016, 11:54:47 AM »
I think that within Composer is JavaScript function which achieve it, try to check the provided samples.
Offline ymattica
« Reply #2 on: February 05, 2016, 02:26:30 PM »
I need to read a transaction list in  a Voice application .
There are some funtion in GenesysOrchestrationFuntions when you are using a routing application ( WorkFlow ) but it seem not possible when you are using a voice application :'(
I could use the interaction data block when the application starts, but there are many variables to read and I do not always serve them all...
« Reply #3 on: February 05, 2016, 02:40:56 PM »
Within voice application is not possible by default. So, you have to reinvent your own way - for example through the database directly or via any custom service which will provide you with the data
Offline ymattica
« Reply #4 on: February 05, 2016, 02:49:22 PM »
thanks a lot
I had thought to make a direct request to the DB even if this solution does not really like !
Regards
