" /> GVP 8 & WebLogic? - Genesys CTI User Forum
Author Topic: GVP 8 & WebLogic?  (Read 7761 times)
Adam G
GVP 8 & WebLogic?
« on: March 04, 2016, 11:36:09 AM »
I've been trawling for any info on GVP 8 utilizing WebLogic (version?) for deployments, but can't find any references... does anyone have any info on this?  Can GVP 8 utilize WebLogic - or does it have to be IIS/Tomact/Apache...? The standard compatibility documents contain no reference to this - either that, or I am missing the point! :(
Thanks!
Re: GVP 8 & WebLogic?
« Reply #1 on: March 04, 2016, 12:06:33 PM »
  • I would test by just creating a Java Project, export to WAR and then test the libraries working on WebLogic.
    Should be a simple test
    Adam G
    « Reply #2 on: March 04, 2016, 12:09:06 PM »
  • Thanks cav - I was actually looking for a statement of compatibility from Genesys, as a reference.  I understand that, by design, it [i]should[/i] work... but I need documented proof from the vendor.
    « Reply #3 on: March 04, 2016, 12:13:19 PM »
  • Let me look at some docs I have. Will return to you in a few hours. If do, will send it to you directly
    « Reply #4 on: March 04, 2016, 12:16:33 PM »
  • A quick search on support site states that no, is not supported. Others already asked for it.
    Adam G
    « Reply #5 on: March 04, 2016, 12:18:11 PM »
  • Thanks for the confirmation cav! :)
    Offline zafzef.mourad
    « Reply #6 on: March 05, 2016, 10:04:07 PM »
  • WebLogic and WebSphere are supported with GVP 8 ...so you can deploy your Composer, VXML and Java application....we used for our deployment in a big bank
    Envoyé de mon Nexus 5 en utilisant Tapatalk
    « Reply #7 on: March 05, 2016, 10:16:30 PM »
  • ? Any doc sustaining that?
    « Reply #8 on: March 06, 2016, 03:00:16 AM »
  • If u have a Genesys account so sign in and open this URL and see section "Application Server Requirements"
    « Reply #9 on: March 06, 2016, 03:01:05 AM »
  • If not so here is the section:
    Genesys does not certify Composer with specific Web application server vendors and versions. This applies to developing both:
    VXML applications and related resources that will be executed on the Genesys Voice platform andSCXML applications and related resources that will be executed on the Orchestration platform.
    Java Composer Projects can be deployed to any Web application server that meets the following minimum pre-requisites:
    Application server should be J2EE 5 compliant.Support for the JSP 2.1/Servlet 2.5 specification.
    When considering a potential Web application server to use for a production deployment of Composer-generated applications, please refer to the vendor's documentation to ensure that the software meets these pre-requisites. In addition, you should run a few basic tests using a Composer sample application, to ensure that the application behaves as expected. For more details, please refer to the section Suggested Test Plan.
    For developing SCXML applications and related resources that will be executed on the Orchestration Server platform, only specific Web application servers are supported. Please refer to the Orchestration Server 8.1 Deployment Guide for more information.
    Note: For more detailed information on deploying Composer applications to an application server, see Deploying Composer Applications.
    Adam G
    « Reply #10 on: March 06, 2016, 10:09:24 AM »
  • Thanks guys,
    I also got a little more information on the subject which indicates that WebLogic can be used with VXML if the underlying data stream is standard HTTP/HTTPS but it has not necessarily been confirmed against any non-standard data stream.
    Pretty much the same as noted in this thread...
    « Reply #11 on: March 06, 2016, 05:43:30 PM »
  • only thing I could find on all G support site:
    [quote]
    Connection Pooling for WebLogic Application Servers
    When the application Server is WebLogic, there must be an extra configuration file in WEB-INF called weblogic.xml.  First, though, confirm that the following is present in web.xml in the exported .war file: <resource-ref>                <res-ref-name>jdbc/poolDS</res-ref-name>                <res-type>javax.sql.DataSource</res-type>                <res-auth>Container</res-auth> </resource-ref> res-ref-name should match the pool name in the connection.properties file, and it should be prefixed by jdbc/. weblogic.xml File The weblogic.xml can be added to the Composer Project in WEB-INF.  Afterwards, you will have to export the .war file from Composer again and redeploy.  The weblogic.xml should contain: <?xml version="1.0" encoding="UTF-8"?> <wls:weblogic-web-app xmlns:wls="http://xmlns.oracle.com/weblogic/weblogic-web-app&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="http://java.sun.com/xml/ns/javaee http://java.sun.com/xml/ns/javaee/ejb-jar_3_0.xsd http://xmlns.oracle.com/weblogic/weblogic-web-app http://xmlns.oracle.com/weblogic/weblogic-web-app/1.2/weblogic-web-app.xsd&quot;>    <wls:resource-description>        <wls:res-ref-name>jdbc/poolDS</wls:res-ref-name>        <wls:jndi-name>poolDS</wls:jndi-name>    </wls:resource-description> </wls:weblogic-web-app> Note the following: The wls:res-ref-name should match res-ref-name in web.xml. wls:jndi-name should be the JNDI Name in the WebLogic configuration.
    This is from Composer docs
    « Last Edit: March 06, 2016, 05:49:15 PM by cavagnaro »
