" /> Softphone is happy in VS 2010, but not 2015 - Genesys CTI User Forum
Author Topic: Softphone is happy in VS 2010, but not 2015  (Read 3833 times)
Offline bluelionpiper
« on: April 13, 2016, 04:10:21 PM »
I recently moved into Genesys softphone dev and while I never done any dev work with softphones I come from a heavy .net background.  While I was adding some custom code I noticed that when I tried to run the whole package that an exception would be thrown in one of the Genesys dll's BUT it only happened in Visual Studio 2015.  I can run the code in VS 2010 and 2013.
Here is the exception details:
Microsoft.Practices.Unity.ResolutionFailedException was unhandled
Message: An unhandled exception of type 'Microsoft.Practices.Unity.ResolutionFailedException' occurred in Microsoft.Practices.Unity.dll
Additional information: Resolution of the dependency failed, type = "Genesyslab.Desktop.Infrastructure.IBootstrapController", name = "". Exception message is: The current build operation (build key Build Key[Genesyslab.Desktop.Infrastructure.IBootstrapController, null]) failed: The current type, Genesyslab.Desktop.Infrastructure.IBootstrapController, is an interface and cannot be constructed. Are you missing a type mapping? (Strategy type BuildPlanStrategy, index 3)
Any help would be great!
Re: Softphone is happy in VS 2010, but not 2015
« Reply #1 on: April 14, 2016, 06:09:35 AM »
Did you check the used .Net version?
« Reply #2 on: April 14, 2016, 02:16:46 PM »
Yes.  Right now it's in 3.5.  I tried converting it to 4.0 and seeing if it made VS 2015 happy, but i got the same error.
Offline Konoli34
« Reply #3 on: August 03, 2022, 08:03:00 AM »
Hi ,
Does anyone know the solution to the error? I Use VS 2022 and Framework 4.5.2
I showed the DLLs but when I try to run I get the error . Is there anyone who can be of assistance? Thank you in advance
Offline hsujdik
« Reply #4 on: August 03, 2022, 12:37:24 PM »
Did you add the References for Genesyslab.Desktop.Infrastructure.dll (and all other Genesyslab.Desktop.* and Microsoft.* DLLs) on your project?
Offline Konoli34
« Reply #5 on: August 07, 2022, 12:04:59 PM »
Hello ,
@hsujdik
Yes, the dlls you sent are attached, but VS also gives this warning, but the application works. I'm trying to make a VideoCall.
I'm trying to make a VideoCall call with an API link.
With WebView2, but I trigger the Navigate link, but Genesys Worspace Edition does not open in WPF. This took my time, can anyone help with an idea?
Thanks in advance
« Last Edit: August 07, 2022, 12:09:14 PM by Konoli34 »
Offline hsujdik
« Reply #6 on: August 07, 2022, 10:53:32 PM »
There is a page about how to use the WebView2. Have you seen it?
https://docs.genesys.com/Documentation/IW/latest/Developer/Chromium
[quote]
In the page I mentioned above, it says that it requires .NET Framework 4.6.2 or higher (and also, WDE 8.5.147.05 or above).
Offline Konoli34
« Reply #7 on: August 12, 2022, 09:31:10 AM »
Hi hsujdik ,
Thank you very much for your support. I provided Framawork upgrade and editing.
But at this point when i put try cath i get error
This is causing a lot of trouble. WebView2 Tool installation is not installed separately on user computers for a different issue. Do you have any idea for this?
Thank you
Error Message :
System.BadImageFormatException: An attempt was made to load a program with an incorrect format. (Exception from HRESULT: 0x8007000B)
  at Microsoft.Web.WebView2.Core.CoreWebView2Environment.CreateCoreWebView2EnvironmentWithOptions(String browserExecutableFolder, String userDataFolder, ICoreWebView2EnvironmentOptions options, ICoreWebView2CreateCoreWebView2EnvironmentCompletedHandler environment_created_handler)
  at Microsoft.Web.WebView2.Core.CoreWebView2Environment.<CreateAsync>d__3.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
  at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
  at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
  at System.Runtime.CompilerServices.TaskAwaiter`1.GetResult()
  at Genesyslab.Desktop.Modules.ABIntegration.Views.WebView2SampleView.<InitializeAsync>d__14.MoveNext() in
