" /> [RESOLVED] Install Configuration Manager on Windows 10? - Genesys CTI User Forum
Author Topic: [RESOLVED] Install Configuration Manager on Windows 10?  (Read 10094 times)
Offline hsujdik
« on: April 13, 2016, 10:54:58 PM »
Has anyone been able to install Configuration Manager on Windows 10?
My co-workers who had Windows 8 with CME installed, migrated to Windows 10 and it kept running fine.
However, I am trying to install CME on a fresh Windows 10 Pro and can't get rid of "incompatible Windows operating system" during the installation, even when trying to run on Compatibility Mode.
Does anyone know how to work around this?
Version: 8.1.100.07
Thanks in advance.
« Last Edit: April 14, 2016, 05:13:45 PM by hsujdik »
Re: Install Configuration Manager on Windows 10?
« Reply #1 on: April 14, 2016, 02:49:40 AM »
Not supported. Use GA or GAX
Offline terry
« Reply #2 on: April 14, 2016, 04:00:24 AM »
If you like experiments - add proper section OS into ip_description.xml file.
Offline Locust
« Reply #3 on: April 14, 2016, 10:44:44 AM »
I instaled CM ver: 8.1.100.06 on Windows 10 pro by using compatibility mode. CM is working properly.
Version 8.1.100.07 is unable to install with all compatibility mode settings (i tried).
« Last Edit: April 14, 2016, 01:52:33 PM by Locust »
Offline hsujdik
« Reply #4 on: April 14, 2016, 05:13:28 PM »
Thank you, Locust. 8.1.100.06 worked perfectly!
Offline enrique
« Reply #5 on: November 10, 2016, 10:09:08 PM »
[quote author=terry link=topic=9534.msg43012#msg43012 date=1460606424]
This worked fine in my case for Windows 10 and CME.
