" /> Multi site configuration - Genesys CTI User Forum
Author Topic: Multi site configuration  (Read 3425 times)
Zygis
2 sites (we want create multi site) in one site is G6.5 in another G5.1, then stat server from (G6.5) is looking for available agents in site (G5.1), it did not get answer, error "unknown server"(from log file).
Where is a problem?
Marked as best answer by on Today at 05:23:56 PM
Peri
  • Undo Best Answer
  • Does you 5.1 environment share the same CME as 6.5?
    If not, you will get this error.
    What you need to do is recreate your G5.1 TServer entry in the CME used by your StatServer. Also, MAKE SURE THAT serverid's are different for these TServers!
