" /> CPD will not dialing - Genesys CTI User Forum
Author Topic: CPD will not dialing  (Read 3337 times)
Henry
Hi, can you help me please.
Have you ever seen trace from CPD Server like this? (see below)
What does it mean "dt_setsigmod failed: dtiB1T4"
The dialogic is working (i think so) correctly, because I can make a call from isdiag. So where could be the problem.
Thanks for help
Open LCALayer on port=4999
LCA Library version 6.5.000.10
05/23/03 10:43:27.445 Standard ctimm4 CPD_Server GCTI1010005 Configuration object was read: object_type: CFGSwitch, object_name: G3_Switch, DBID: 101
For tenant: 0, on switch: 101 have been found 1002 DNs.
Folder 'G3_Switch>DNs' has been read successfully.
Folder 'G3_Switch>DNs>CPD_Ports' has been read successfully.
Folder 'G3_Switch>DNs>CPD_Ports>regular' has been read successfully.
Folder 'G3_Switch>DNs>CPD_Ports>regular>dxxxB1' has been read successfully.
DXX Channel: dxxxB1C1, DN: 91300, type: CallProcessingPort has been added as Regular.
DXX Channel: dxxxB1C2, DN: 91301, type: CallProcessingPort has been added as Regular.
DXX Channel: dxxxB1C3, DN: 91302, type: CallProcessingPort has been added as Regular.
DXX Channel: dxxxB1C4, DN: 91303, type: CallProcessingPort has been added as Regular.
Folder 'G3_Switch>DNs>CPD_Ports>regular>dtiB1' has been read successfully.
DTI Channel: dtiB1T1, DN: 1300, type Extension has been added as Regular.
DTI Channel: dtiB1T2, DN: 1301, type Extension has been added as Regular.
DTI Channel: dtiB1T3, DN: 1302, type Extension has been added as Regular.
DTI Channel: dtiB1T4, DN: 1303, type Extension has been added as Regular.
Connected to LCA at host ctimm4, port 4999
LCALayer: REventRegistered on LCA...
05/23/03 10:43:37.570 Trace ctimm4 CPD_Server GCTI04520 New client 596 connected
05/23/03 10:43:37.664 Trace ctimm4 CPD_Server GCTI04541 Message Req_RegisterClient received from 596 ( Unknown NULL )
CPDServerMessage: Req_RegisterClient
SATRCFG_PROTOCOL SDProtocol 5.2
SAttr_ApplicationName OC_Server_5
05/23/03 10:43:37.664 Trace ctimm4 CPD_Server GCTI04541 Message Req_DialerMode received from 596 ( Unknown OC_Server_5 )
CPDServerMessage: Req_DialerMode
IATRCFG_REQUESTID 168
05/23/03 10:43:37.664 Trace ctimm4 CPD_Server GCTI04542 Message Rsp_RequestResponse sent to 596 ( Unknown OC_Server_5 )
CPDServerMessage: Rsp_RequestResponse
IAttr_DialerMode TServerTransfer
IAttr_ErrorCode No error
IAttr_CallStatus No status
IAttr_CallProgress Ok
05/23/03 10:43:51.585 Trace ctimm4 CPD_Server GCTI04541 Message Req_MakePredictiveCall received from 596 ( Unknown OC_Server_5 )
CPDServerMessage: Req_MakePredictiveCall
LAttr_SwitchDBID 101
SAttr_DialTo 0903564443
LAttr_ConnectedTransferDBID 831
IAttr_DetectionMode NoTypeRecognition
IAttr_ConnectedTimeout 120
IAttr_OrigEstablishTimeout 4
IAttr_WaitInQueueTimeout 10
IAttr_CallTransferType OneStepTransfer
BAttr_UserData
'GSW_CHAIN_ID' 5
'GSW_CALL_RESULT' 28
'GSW_ATTEMPT' 0
'GSW_PHONE' '0903564443'
'GSW_PHONE_TYPE' 1
'GSW_RECORD_TYPE' 2
'GSW_TZ_OFFSET' 7200
'GSW_RECORD_HANDLE' 67
'GSW_CALLING_LIST' 'CL_Akvizicia'
'GSW_CAMPAIGN_NAME' 'Akvizicia_initial'
'GSW_APPLICATION_ID' 205
IATRCFG_REQUESTID 169
ThID: 2368: making a call to '0903564443'
ThID: 2368: seizing voice channel dxxxB1C2
ThID: 2368: Enable PVD by default
ThID: 2368: seizing T1/E1 data channel dtiB1T4
ThID: 2368: dt_setsigmod failed: dtiB1T4
ThID: 2368: T1/E1 data channel released: dtiB1T4
ThID: 2368: voice channel released: dxxxB1C2
05/23/03 10:43:52.742 Trace ctimm4 CPD_Server GCTI04542 Message Rsp_CallProgress sent to 596 ( Unknown OC_Server_5 )
CPDServerMessage: Rsp_CallProgress
IAttr_CallStatus Error during making a call
IAttr_CallProgress NoProgress
