" /> Not Ready Reason - Genesys CTI User Forum
Author Topic: Not Ready Reason  (Read 2785 times)
Offline anandapriyan
Not Ready Reason
« on: June 21, 2016, 11:37:24 AM »
Whether it is possible in the CCPulse to show the Not Ready reason duration in a single custom stat. i.e Break,Lunch.
I have created the custom stat for current not ready time.
[b]MainMask- Not Ready For Next Call
Subject - AgentStatus
Category-CurrentTime
Objects - Agent,GroupAgents,Place,GroupPlaces.
[/b]
I have created the separate stat to apply filters for each not ready reason.
Looking Forward for Your Suggestions.
Re: Not Ready Reason
« Reply #1 on: June 21, 2016, 12:06:55 PM »
Search the forum please. With VB script is possible
« Reply #2 on: July 07, 2016, 11:04:04 AM »
Thanks For your Reply,
I have tried the following method, In the Filter options if we give the Conditions such as Break ||[or] Lunch.
When the agent goes to the [b]Not ready Reason Break[/b]  It will start the duration  but when the agent goes to the not ready reason lunch , the stat not get counting from start. Kindly looking forward for your suggestions.
I used the VB Script to display the not ready reason name, But i need the [b]suggestions [/b]on the not ready reason [b]duration[/b] in the single stat .
« Last Edit: July 07, 2016, 11:09:36 AM by anandapriyan »
Offline Tambo
« Reply #3 on: July 07, 2016, 12:41:37 PM »
search for ccpulse on here there are plenty of posts to tell you exactly what to do with filters etc
Offline Tambo
« Reply #4 on: July 07, 2016, 12:45:01 PM »
or search PairExist which will give you the filters
Offline n3vek7
    • ITKB
« Reply #5 on: July 07, 2016, 05:37:29 PM »
You'll find more info in StatServer user guide, search for filters.
Here's an example : PairExists(Reasons, "NotReadyReasonCode", [value])
