" /> Audio file corrupt when using g729 - Genesys CTI User Forum
Author Topic: Audio file corrupt when using g729  (Read 2020 times)
Offline Ricktn
« on: August 11, 2016, 07:13:41 PM »
I have problems with calls made with the IWS as calls are recorded corrupt however with eyebeam if recorded properly.
I edit the file Edpoint.config to ensure that the g729 codec use and if it does .
someone has already encountered this case ?, I would appreciate if you can guide me about it.
Best regards.
Re: Audio file corrupt when using g729
« Reply #1 on: August 12, 2016, 06:11:31 AM »
It also depends on SIP server codec configuration. What say logs? what about SIP signalization - what do you see there, in SDP?
