" /> Stats are Shown as NA -- Issue solved - Genesys CTI User Forum
Author Topic: Stats are Shown as NA -- Issue solved  (Read 3055 times)
Offline anandapriyan
« on: September 12, 2016, 10:16:50 AM »
Team,
In CCPulse application all the stats are showing as NA. How to solve this issue. Kindly looking forward for your solutions.
« Last Edit: September 19, 2016, 11:07:26 AM by anandapriyan »
Re: Stats are Shown as NA
« Reply #1 on: September 12, 2016, 10:37:15 AM »
Check your statserver state and configuration
Adam G
« Reply #2 on: September 12, 2016, 01:06:20 PM »
As above, plus;
Make sure your copy of CCPulse is pointing to the [i]right [/i]StatServer - or, in fact, that it is connected to [i]any [/i]StatServer! :)
Offline Tambo
« Reply #3 on: September 12, 2016, 10:56:18 PM »
this may also explain some of your other stats issues, fix ccpulse first
« Reply #4 on: September 13, 2016, 09:59:31 AM »
Thanks for your reply. After adding the host name in the HOST file. All the stats in the CCPulse is working fine.
Adam G
« Reply #5 on: September 13, 2016, 01:38:21 PM »
Thanks for letting us know.  Please update the Subject heading with " - Solved"
Offline Dionysis
« Reply #6 on: September 13, 2016, 06:33:39 PM »
I'm hoping this is a lab environment?  If not, you really need to figure out why you weren't able to resolve the host name using DNS.
Adam G
« Reply #7 on: September 14, 2016, 07:46:59 AM »
[quote author=Dionysis link=topic=9834.msg44632#msg44632 date=1473791619]
Seconded.  Otherwise, every local install you make of CCPulse will need a Host File tweak....
