" /> How to set auto answer for single step consult and transfer call in WDE? - Genesys CTI User Forum
Author Topic: How to set auto answer for single step consult and transfer call in WDE?  (Read 3111 times)
Offline bala14492
Hi dudes,
      I set in my configuration "voice.auto-answer" is true.it will auto answer for incoming calls.Fine.but when i try to single step transfer or consult means in show the toaster popup to accept calls.how to set that also auto answer?
Re: How to set auto answer for single step consult and transfer call in WDE?
« Reply #1 on: September 21, 2016, 11:47:38 AM »
On what level did you configure the auto-answer function?
Offline bala14492
« Reply #2 on: September 21, 2016, 11:50:43 AM »
application level and also agent level
Offline Tambo
« Reply #3 on: September 21, 2016, 11:52:08 AM »
what is your    voice.one-step-trsf-mode  set to ?
Offline bala14492
« Reply #4 on: September 21, 2016, 11:55:37 AM »
voice.one-step-trsf-mode =default
Offline Tambo
« Reply #5 on: September 21, 2016, 11:59:34 AM »
is your routing strategy making this happen ?? check that
Offline bala14492
« Reply #6 on: September 21, 2016, 12:04:24 PM »
In my Routing strategy, i just add user data keys only....how to check that?
Offline Tambo
« Reply #7 on: September 21, 2016, 12:08:22 PM »
do you not have a separate transfer routing strategy ??  it's not normally in your main one.
Offline hsujdik
« Reply #8 on: September 21, 2016, 06:37:22 PM »
is your transfer done directly to an Agent / Extension or does it come through a Routing Point? If its the first case, try changing inbound-bsns-call option to true in SIP Server application under TServer section.
Edit:
And, by the way, try with an older version of WDE. A co-worker had a very similar problem which happened to be a bug in one of the newest versions of WDE. He downgraded to one version below and got it back working again. The version he was having problems was 8.5.114.08
« Last Edit: September 21, 2016, 06:55:46 PM by hsujdik »
