" /> Routing Issue - Genesys CTI User Forum
Author Topic: Routing Issue  (Read 3194 times)
Offline livinginnj
Routing Issue
« on: September 28, 2016, 11:01:26 PM »
Hi i am facing the below issue, Strategy is not executing in the RP 1260955. It is present in Avaya Switch.Any thoughts what is the root cause?
received from 65531(tserv_a)xxenp001:3000(fd=) message EventError
(Invalid origination or destination address)
AttributeErrorMessage 'Invalid origination or destination address'
AttributeReferenceID 23958993
AttributeThisDN '1260955'
AttributeConnID 0079028b99a62661
AttributeCallID 11013
AttributeErrorCode 600
AttributeTimeinSecs 1475101094 (15:18:14)
AttributeTimeinuSecs 650136
AttributeCustomerID 'Resources'
AttributeEventSequenceNumber 0000000002fa5b60
Re: Routing Issue
« Reply #1 on: September 29, 2016, 02:17:36 AM »
Show the TRoute request and full log
Offline livinginnj
Re: Routing Issue
« Reply #2 on: September 29, 2016, 02:28:18 AM »
2016-09-28T15:18:14.648  Trace  xxenp001 tserv_a  GCTI-00-04541  RequestRouteCall received from [15] (00000002 urs_a 10.193.x.1:39886)
message RequestRouteCall
AttributeOtherDN ''
AttributeExtensions [44] 00 02 00 00..
'CUSTOMER_ID' 'Resources'
'SWITCH' 'RB8800'
AttributeRouteType 1 (RouteTypeDefault)
AttributeReason [14] 00 01 01 00..
'RTR' 365
2016-09-28T15:18:14.648  Interaction  xxenp001 tserv_a  GCTI-00-04543  Interaction message "RequestRouteCall" received from 15 ("urs_a")
TDN:1260955
IID:0079028B99A62661
ODN:
OPER:36
@15:18:14.6489 [gctmi] Distributing request RequestRouteCall
@15:18:14.6489 [asai] Party [0079028b99a62661:1260955,s809,tRP,rDST,lINT] (reqRouteCall)
TP_AsaiData
FACILITY  CRV:9ca0
Facility: INVOKE
InvokeId: 2
Operation: RouteSelect
CalledNum: (unknown),''
@15:18:14.6490 [>>] 08 00 00 16 08 02 9C A0 62 96 1C 0E 91 A1 0B 02 01 02 02 01 B7 40 03 70 01 80
@15:18:14.6500 [<<] 08 00 00 17 08 02 1C A0 5A 96 1C 0F 91 A1 0C 02 01 02 02 01 B9 40 04 08 02 81 9C
TP_AsaiData
RELEASE_COMPLETE  CRV:1ca0
Facility: INVOKE
InvokeId: 2
Operation: RouteEnd
Cause: C_INVLDNUM
@15:18:14.6501 [asai] (processOperRouteEnd)
@15:18:14.6501 [gctmi] TMsg [EventError()] distributing to model
@15:18:14.6501 [gctmi] Party [0079028b99a62661:1260955,s809,tRP,rDST,lINT] processError
@15:18:14.6501 [gctmi] request RequestRouteCall ctiRefId 40096 removed from reqMgr
@15:18:14.6501 [0] 8.1.001.55 send_to_client: message EventError
2016-09-28T15:18:14.650  Interaction  xxenp001 tserv_a  GCTI-00-04545  Interaction message "EventError" sent to 15 ("urs_a")
TDN:1260955
OPER:52
2016-09-28T15:18:14.650  Trace  xxenp001 tserv_a  GCTI-00-04542  EventError sent to [15] (00000002 urs_a 10.193.x.1:39886)
Re: Routing Issue
« Reply #3 on: September 29, 2016, 07:07:13 AM »
From my point of view, the OtherDN parameter is missing, respectively has empty value, which means you wanted to route to "null" destination and the PBX declined it. Check your strategy.
Re: Routing Issue
« Reply #4 on: September 29, 2016, 01:20:14 PM »
Agree with Kubig
Offline livinginnj
Re: Routing Issue
« Reply #5 on: September 29, 2016, 08:41:56 PM »
We use the same strategy for other Transfer Numbers  it all works. Only for one number it is not working so
Re: Routing Issue
« Reply #6 on: September 29, 2016, 09:04:39 PM »
So...check your strategy or configuration
Offline Tambo
Re: Routing Issue
« Reply #7 on: September 30, 2016, 10:24:29 AM »
delete RP and re-create from working one maybe ?!?
Re: Routing Issue
« Reply #8 on: September 30, 2016, 10:26:44 AM »
[quote]delete RP and re-create from working one maybe ?!?[/quote] Why?? ???
Offline Tambo
Re: Routing Issue
« Reply #9 on: September 30, 2016, 10:51:03 AM »
can be corrupt during creation, had it before with route points
Re: Routing Issue
« Reply #10 on: September 30, 2016, 12:05:33 PM »
RP corrupt? Hummmm could be not monitored and then you force the register again but not corrupt... It is just a DB object which is sent to TServer to ask for a Monitor request to the PBX :S
Offline Tambo
Re: Routing Issue
« Reply #11 on: September 30, 2016, 12:44:31 PM »
seriously it didn't show as being registered in logs, honestly  ;D
Offline n3vek7
    • ITKB
Re: Routing Issue
« Reply #12 on: September 30, 2016, 02:18:57 PM »
Corrupt, isn't it a generic answer when you don't know what was the problem and you just restarted a service?  ;D
Agree with cavagnaro/Kubig, RP is probably not monitored by TServer and it just doesn't exist. Make sure it is registered.
