" /> SIP SERVER - Genesys CTI User Forum
Author Topic: SIP SERVER  (Read 3685 times)
Offline sere9890
SIP SERVER
« on: October 04, 2016, 03:25:08 PM »
Hi all,
after having installed the SIP server, started the service and configured the application, while trying to start the application from GAX, i'm shown the message "start pending".
when checking the alarm tab in gax dashboard, the following status is reported:
Severity:            major
Alarm title:        application failure
Application:      sip server
Message:          application type: TServer. Application terminated due to internal condition
can someone help me in finding the cause of the problem?
thanks a lot to every one
Offline Tambo
Re: SIP SERVER
« Reply #1 on: October 04, 2016, 03:52:02 PM »
check application logs
Offline sere9890
Re: SIP SERVER
« Reply #2 on: October 04, 2016, 03:56:02 PM »
No log is created since the application does not start
Re: SIP SERVER
« Reply #3 on: October 04, 2016, 04:44:40 PM »
Start it as console, via bat file and see what is printed out
Offline sere9890
Re: SIP SERVER
« Reply #4 on: October 06, 2016, 12:54:48 PM »
how can i make it?
thanks
Re: SIP SERVER
« Reply #5 on: October 06, 2016, 02:20:45 PM »
Really? Double click the bat file...geeeee
Offline n3vek7
    • ITKB
Re: SIP SERVER
« Reply #6 on: October 17, 2016, 02:13:32 PM »
Double clicking the batch file may print and close write away the console.
Try opening a prompt before (Start - Run and type "cmd"). Then go to the installation path of SIP Server (ex: D:\GCTI\SIPServer) and start the batch.
Re: SIP SERVER
« Reply #7 on: October 17, 2016, 02:43:38 PM »
In case, there is no log created, it seems like the T-Server is not able to connect to the configuration server (it can be caused by incorrect configuration on SIP Server process/services, network outage, incorrect configuration on SIP server application object, etc)
Re: SIP SERVER
« Reply #8 on: October 17, 2016, 03:01:22 PM »
In my humble opinion, if you have to teach someone how to handle a bat file then sorry he is not ready to provide support...
Offline nonny
Re: SIP SERVER
« Reply #9 on: October 17, 2016, 06:05:43 PM »
Lrm
Sent from my SM-N9005 using Tapatalk
