" /> SIP Server installation - Genesys CTI User Forum
Author Topic: SIP Server installation  (Read 1847 times)
Offline sere9890
« on: October 06, 2016, 04:49:35 PM »
Hi all
while installing the SIP Server application i was displayed the following error message
"Your changes could not be saved. Encountered error "Object does not satisfy link condition on CFGFlexibleProperties". Please check each tab for errors."
So i couldn't save the application and apply changes.
Does anyone know what does this mean? what should i do?
Thank a lot
Re: SIP Server installation
« Reply #1 on: October 06, 2016, 04:59:41 PM »
Maybe you forgot to define the server or some info. As said, review your app configuration.
Offline Dionysis
« Reply #2 on: October 11, 2016, 05:14:18 PM »
You have something defined, or not defined, in the options that does not satisfy the meta data for your template.  You should be able to see it quite easily by looking at the options tab.
