" /> Alarm detection using variable threshold alert - Genesys CTI User Forum
Author Topic: Alarm detection using variable threshold alert  (Read 2034 times)
Offline janesh22
« on: March 09, 2017, 02:35:38 AM »
Hi ,
I am trying to get more information how to use this feature as I am trying to set up some alarms in our environment here. However there is very less information available regarding the variable threshold alert - alarm detection . Can someone please show me where to go to find more info on this. Also any example implementation that will give me a bettter idea.
Also I am trying to set up alarms for the following log events:
- 00-02004 : Not enough disk space
- 00 -02003 : Insufficient memory
However these seems to be host related alarms rather than application based . So not sure if it will work if i set it up for application. Can some one clarify. I have already checked the log event id help file and not much information provided there either.
Offline Fra
Re: Alarm detection using variable threshold alert
« Reply #1 on: March 09, 2017, 08:31:11 AM »
For the threshold alert, select 'advanced detection mode' in the alarm detection wizard, then add an 'alarm detection script', select 'host variable' which will bring up a mas where you can specify host, monitored resource and thresholds.
For the host-related conditions, selecting 'any application' should make them work.
Offline janesh22
« Reply #2 on: March 09, 2017, 10:18:20 PM »
So are the 2 below ones host related ?
Offline Fra
« Reply #3 on: March 10, 2017, 07:47:31 AM »
Related?
