" /> Could not POST metadata to HTCC - Genesys CTI User Forum
Author Topic: Could not POST metadata to HTCC  (Read 16308 times)
Offline nhannt
« on: June 29, 2017, 11:26:16 AM »
Dear all,
Can you help to check this issue with Recording Processor Script?
Investigation:
recordingProcessor_2017-06-29_16-28-01_075.log
JB6CCUFA4P0UB9MRRBH5SS5II400000G
2017-06-29 16:35:34,825 process_metadata INFO 0 messages have been sent to HTCC.
2017-06-29 16:36:02,897 http_client WARNING Content: {"statusCode":4,"statusMessage":"An internal server error has occurred. Please contact your administrator."}
2017-06-29 16:36:02,928 process_metadata INFO Response: 500. Could not POST metadata to HTCC: JB6CCUFA4P0UB9MRRBH5SS5II400000F
2017-06-29 16:36:02,928 process_metadata WARNING Could not find SM server info. Using default SM. JB6CCUFA4P0UB9MRRBH5SS5II400000F
2017-06-29 16:36:02,928 process_metadata INFO Back up metadata record into [D:\gcti\Recording Processor Script\failed\9f48899a-adf8-471b-aeee-e136fd3f39e7\JB6CCUFA4P0UB9MRRBH5SS5II400000F_20170629-163602.json] was successful.
Test HTCC on Server:
curl -u ops:ops -X POST -d @JB6CCUFA4P0UB9MRRBH5SS5II400000F_20170629-163602.json --header "Content-Type: application/json" http://172.16.1.96:8080/internal-api/contact-centers/9f48899a-adf8-471b-aeee-e136fd3f39e7/recordings
In Configuring the Storage Credentials, I have ignored one failed command:
vi /tmp/create_table
"operationName":"createCRCF"
> curl -u ops:ops -X POST -d @/tmp/create_table http://172.16.1.96:8080/api/v2/ops/contact-centers/9f48899a-adf8-471b-aeee-e136fd3f39e7/recordings --header "Content-Type: application/json"; echo
{"statusCode":4,"statusMessage":"error in call operation"}
Please let me know if you have any idea to fix this issue. Thank you very much!
Br, NhanNT
Re: Could not POST metadata to HTCC
« Reply #1 on: June 29, 2017, 11:33:49 AM »
This seems like issue on IRWS - try to check whether the IRWS is working as expected - ie. you are able to get CCID, etc.
Offline nhannt
« Reply #2 on: June 30, 2017, 01:34:05 AM »
Hi Kubig,
Please share some command to check IRWS is working well. I have executed these commands below.
[root@rws ~]# { curl -u ops:ops -X POST -d @/tmp/add_voice_features http://172.16.1.96:8080/api/v2/ops/contact-centers/9f48899a-adf8-471b-aeee-e136fd3f39e7/features --header "Content-Type: application/json"; echo;}
{"statusCode":0}
[root@rws ~]# vi /tmp/create_table
[root@rws ~]# { curl -u ops:ops -X POST -d @/tmp/create_table http://172.16.1.96:8080/api/v2/ops/contact-centers/9f48899a-adf8-471b-aeee-e136fd3f39e7/recordings --header "Content-Type: application/json"; echo;}
Issue occurs when i try to create operationName, Log at jetty9:
ERROR [ops] [EtsBlEHtRV8UE4LNaB/buA1tyqp9seb4444m8nmh9luzmj9] [] [qtp492999673-24]  /api/v2/ops/contact-centers/9f48899a-adf8-471b-aeee-e136fd3f39e7/recordings  c.g.g.v.a.c.c.CallRecordingsOperationOpsController  error in call operation
com.genesyslab.gir.v2.exceptions.CallRecordingOperationExceptionV2: The call recording records for contact center 9f48899a-adf8-471b-aeee-e136fd3f39e7 already created. ApiResponseV2(statusCode=4, statusMessage=The call recording records for contact center 9f48899a-adf8-471b-aeee-e136fd3f39e7 already created., id=null, uri=null, uris=null, attributes={})
        at com.genesyslab.gir.v2.cassandra.tasks.callrecording.CreateCallRecordingColumnFamiliesCassandraTaskV2.execute(CreateCallRecordingColumnFamiliesCassandraTaskV2.java:43) ~[gir.jar!/:8.5.2]
        at com.genesyslab.gir.v2.api.tasks.callrecording.RecordingOperationApiTaskV2.callCreateCRCF(RecordingOperationApiTaskV2.java:105) ~[gir.jar!/:8.5.2]
        at com.genesyslab.gir.v2.api.tasks.callrecording.RecordingOperationApiTaskV2.onExecute(RecordingOperationApiTaskV2.java:163) ~[gir.jar!/:8.5.2]
        at com.genesyslab.gir.v2.api.tasks.AbstractApiTask$ExecutionFailureExceptionAwareHystrixCommand.run(AbstractApiTask.java:384) ~[gir.jar!/:8.5.2]
        at com.genesyslab.gir.v2.api.tasks.AbstractApiTask$ExecutionFailureExceptionAwareHystrixCommand.run(AbstractApiTask.java:361) ~[gir.jar!/:8.5.2]
        at com.netflix.hystrix.HystrixCommand.executeCommand(HystrixCommand.java:1281) ~[hystrix-core-1.3.16.jar!/:na]
        at com.netflix.hystrix.HystrixCommand.access$2300(HystrixCommand.java:103) ~[hystrix-core-1.3.16.jar!/:na]
        at com.netflix.hystrix.HystrixCommand$5.call(HystrixCommand.java:1186) ~[hystrix-core-1.3.16.jar!/:na]
        at com.genesyslab.cloud.v2.hystrix.GenesysHystrixContextCallable.call(GenesysHystrixContextCallable.java:32) ~[gir.jar!/:8.5.2]
        at com.netflix.hystrix.strategy.concurrency.HystrixContextCallable.call(HystrixContextCallable.java:51) ~[hystrix-core-1.3.16.jar!/:na]
        at java.util.concurrent.FutureTask.run(FutureTask.java:266) ~[na:1.8.0_101]
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) ~[na:1.8.0_101]
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) ~[na:1.8.0_101]
        at java.lang.Thread.run(Thread.java:745) ~[na:1.8.0_101]
Caused by: com.genesyslab.data.RepositoryException: The call recording records for contact center 9f48899a-adf8-471b-aeee-e136fd3f39e7 already created.
        at com.genesyslab.gir.v2.cassandra.repositories.callrecording.CallRecordingRepository.createCFForContactCenterHelper(CallRecordingRepository.java:828) ~[gir.jar!/:8.5.2]
        at com.genesyslab.gir.v2.cassandra.repositories.callrecording.CallRecordingRepository.createCFForContactCenterForKeyspaces(CallRecordingRepository.java:804) ~[gir.jar!/:8.5.2]
        at com.genesyslab.gir.v2.cassandra.repositories.callrecording.CallRecordingRepository.createCFForContactCenter(CallRecordingRepository.java:799) ~[gir.jar!/:8.5.2]
        at com.genesyslab.gir.v2.cassandra.tasks.callrecording.CreateCallRecordingColumnFamiliesCassandraTaskV2.execute(CreateCallRecordingColumnFamiliesCassandraTaskV2.java:34) ~[gir.jar!/:8.5.2]
        ... 13 common frames omitted
Caused by: java.lang.Throwable: Calling Thread included as the last 'caused by' on the chain.
        at sun.misc.Unsafe.park(Native Method) ~[na:1.8.0_101]
        at java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215) ~[na:1.8.0_101]
        at java.util.concurrent.locks.AbstractQueuedSynchronizer.doAcquireSharedNanos(AbstractQueuedSynchronizer.java:1037) ~[na:1.8.0_101]
        at java.util.concurrent.locks.AbstractQueuedSynchronizer.tryAcquireSharedNanos(AbstractQueuedSynchronizer.java:1328) ~[na:1.8.0_101]
        at java.util.concurrent.CountDownLatch.await(CountDownLatch.java:277) ~[na:1.8.0_101]
Thanks, Nhan
« Reply #3 on: June 30, 2017, 04:59:45 AM »
According to the logs it looks like your IVR profile is not completely configured and the Speechminer parameters are missing.
Offline nhannt
« Reply #4 on: July 01, 2017, 03:06:19 AM »
Thanks Kubig,
I have re-checked configuration and metadata have been sent to HTCC. But there is issue on Web Services and metadata haven't written to Cassandra.
Config changed:
[htcc]
# Support CSRF Protection for HTCC
csrfp= 0
Because at Web Service i set: enableCsrfProtection: false
Can you help to check issue on Web Services?
[table][tr][td]
07/01/2017 03:00:27.709 DEBUG [] [] [] [elasticsearch[Bes][index][T#4]]    org.elasticsearch.action.index  [Bes] [call-recordingv2-region1-9f48899a-adf8-471b-aeee-e136fd3f39e7][3], node[w8MutmfBRlOiWg-Ib2uPXA], [P], s[STARTED]: Failed to execute [index {[call-recordingv2-region1-9f48899a-adf8-471b-aeee-e136fd3f39e7][CallRecordings][JB6CCUFA4P0UB9MRRBH5SS5II400001L], source[{"duration":37000,"userData":" [\"00005aCMF6QG000W\"] [\"ON\",\"JB6CCUFA4P0UB9MRRBH5SS5II400001L_5115_2003_2017-07-01_02-53-44_\"] [\"36a61d7c-3213-424e-b880-bc3a022a8caf\",\"84253cfc-2ed7-491d-b8d7-45b09d7c9b9a\"] [\"PAUSED\"] [\"ON\"] [\"ON\"] [3]","mediaFiles":[{"userName":"phuongnd"}],"startTime":1498877622000,"stopTime":1498877659000,"userDataKvps":[{"name":"ContactId","valueStr":"00005aCMF6QG000W"},{"name":"GSIP_REC_FN","valueStr":"JB6CCUFA4P0UB9MRRBH5SS5II400001L_5115_2003_2017-07-01_02-53-44_"},{"name":"IW_CaseUid","valueStr":"36a61d7c-3213-424e-b880-bc3a022a8caf"},{"name":"IW_BundleUid","valueStr":"84253cfc-2ed7-491d-b8d7-45b09d7c9b9a"},{"name":"agentId","valueStr":"2003"},{"name":"ani","valueStr":"5115"},{"name":"dnis","valueStr":"2003"},{"name":"recordDN","valueStr":"2003"},{"name":"agentExtensionDN","valueStr":"2003"},{"name":"callerPhoneNumber","valueStr":"5115"},{"name":"dialedPhoneNumber","valueStr":"2003"},{"name":"callType","valueStr":"Inbound"}],"region":"region1","userName":["phuongnd ACB_Agent phuongnd"],"callType":"Inbound","callerPhoneNumber":"5115","dialedPhoneNumber":"2003","labels":[]}]}]
org.elasticsearch.index.mapper.MapperParsingException: Analyzer [whitespace_lowercase] not found for field [CR.userName]
        at org.elasticsearch.index.mapper.core.TypeParsers.parseField(TypeParsers.java:213) ~[elasticsearch-1.0.1.jar!/:na]
        at org.elasticsearch.index.mapper.core.StringFieldMapper$TypeParser.parse(StringFieldMapper.java:156) ~[elasticsearch-1.0.1.jar!/:na]
        at org.elasticsearch.index.mapper.object.ObjectMapper$TypeParser.parseProperties(ObjectMapper.java:258) ~[elasticsearch-1.0.1.jar!/:na]
        at org.elasticsearch.index.mapper.object.ObjectMapper$TypeParser.parse(ObjectMapper.java:216) ~[elasticsearch-1.0.1.jar!/:na]
        at org.elasticsearch.index.mapper.DocumentMapperParser.parse(DocumentMapperParser.java:203) ~[elasticsearch-1.0.1.jar!/:na]
        at org.elasticsearch.index.mapper.DocumentMapperParser.parseCompressed(DocumentMapperParser.java:185) ~[elasticsearch-1.0.1.jar!/:na]
        at org.elasticsearch.index.mapper.MapperService.parse(MapperService.java:387) ~[elasticsearch-1.0.1.jar!/:na]
        at org.elasticsearch.index.mapper.MapperService.merge(MapperService.java:253) ~[elasticsearch-1.0.1.jar!/:na]
        at org.elasticsearch.index.mapper.MapperService.documentMapperWithAutoCreate(MapperService.java:416) ~[elasticsearch-1.0.1.jar!/:na]
        at org.elasticsearch.index.shard.service.InternalIndexShard.prepareIndex(InternalIndexShard.java:391) ~[elasticsearch-1.0.1.jar!/:na]
        at org.elasticsearch.action.index.TransportIndexAction.shardOperationOnPrimary(TransportIndexAction.java:203) ~[elasticsearch-1.0.1.jar!/:na]
        at org.elasticsearch.action.support.replication.TransportShardReplicationOperationAction$AsyncShardOperationAction.performOnPrimary(TransportShardReplicationOperationAction.java:556) ~[elasticsearch-1.0.1.jar!/:na]
        at org.elasticsearch.action.support.replication.TransportShardReplicationOperationAction$AsyncShardOperationAction$1.run(TransportShardReplicationOperationAction.java:426) [elasticsearch-1.0.1.jar!/:na]
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [na:1.8.0_101]
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [na:1.8.0_101]
        at java.lang.Thread.run(Thread.java:745) [na:1.8.0_101]
07/01/2017 03:00:27.768 [b]ERROR [/b][ops] [EtsBlEHtRV8UE4LNaB/buA1m8cubjw1ey0jjv9w6mdiusto] [] [hystrix-ApiCreatePool-51]  /internal-api/contact-centers/9f48899a-adf8-471b-aeee-e136fd3f39e7/recordings  c.g.g.v.a.t.c.CreateCallRecordingApiTaskV2  Error indexing call recording CallRecording(id=JB6CCUFA4P0UB9MRRBH5SS5II400001L, ccid=9f48899a-adf8-471b-aeee-e136fd3f39e7, callerPhoneNumber=5115, dialedPhoneNumber=2003, startTime=Sat Jul 01 09:53:42 ICT 2017, mediaFiles=[CRMediaFile(mediaDescriptor=CRStorageMediaDescriptor(storage=webDAV, storageVersion=null, path=http://172.16.1.96/recordings/2017-07-01T02%253A53%253A44Z_JB6CCUFA4P0UB9MRRBH5SS5II400001L_2003-00C60195-10002984-00000001.mp3, data=null, auth=null)
Thanks, Nhan.[/td][/tr][/table]
« Reply #5 on: July 01, 2017, 06:53:37 AM »
This is problem with ElasticSearch not with the IRWS
Odesláno z mého D5803 pomocí Tapatalk
Offline nhannt
« Reply #6 on: July 04, 2017, 04:09:29 AM »
Hi Kubig,
I changed gir.jar and metadata posted to HTCC.
Changed: default-mapping.json
        "CR.userName":{
            "type":"string",
        "index":"analyzed",
        "analyzer":"whitespace_lowercase"
to
        "CR.userName":{
            "type":"string",
        "index":"analyzed",
        "analyzer":"whitespace"
But it failed when post to Interaction Receiver of SpeechMiner.
recordingProcessor_2017-07-04_09-44-02_259.log
2017-07-04 10:27:40,121 process_metadata DEBUG Sending to HTCC: 3J5IOAB4R930BC27GD9PTHDSS400000R
2017-07-04 10:27:40,151 metadata_client DEBUG POST: http://172.16.1.96:8080/internal-api/contact-centers/9f48899a-adf8-471b-aeee-e136fd3f39e7/recordings: Response Status: 200
2017-07-04 10:27:40,151 metadatarecord DEBUG Could not find rp.speechminer_uri in record.
2017-07-04 10:27:40,151 metadatarecord DEBUG Could not find rp.speechminer_auth in record.
2017-07-04 10:27:40,151 process_metadata WARNING Could not find SM server info. Using default SM. 3J5IOAB4R930BC27GD9PTHDSS400000R
I see that MCP didn't get infor of speechminer_uri and speechminer_auth in IVR Profiles to write to metadata file? Do you have any idea to fix this issue?
Thanks, Nhan
« Reply #7 on: July 04, 2017, 04:48:19 AM »
Are the rp. parameters filled correctly on IVR profile level?
Offline nhannt
« Reply #8 on: July 06, 2017, 08:39:44 AM »
Yes,
I have configured IVR Profile contain rp.speechminer_uri and rp.speechminer_auth but MCP didn't get this infor and write to metadata files.
[code]
gvp.service-parameters/recordingclient.rp.speechminer_auth
fixed,default:password
gvp.service-parameters/recordingclient.rp.speechminer_uri
fixed,http://172.16.1.21/interactionreceiver[/code]
Further, do you know where configure for user/password of Interaction Receiver? Because, After deployment Interaction Receiver, I can access to http://172.16.1.21/interactionreceiver/ without user/password.
[code]http://172.16.1.21/interactionreceiver/
Hello[/code]
Thanks, Nhan
« Reply #9 on: July 06, 2017, 02:10:25 PM »
Try a MCP reset
Offline nhannt
« Reply #10 on: July 06, 2017, 03:22:34 PM »
Hi cavagnaro,
I have reset MCP many times but it still don't work. It have get info of Web Services and send file .mp3 and metadata to HTCC but not get info of SpeechMiner and Interaction Receiver.
Config in IVR Profiles:
[code]gvp.service-parameters/recordingclient.callrec_dest
fixed,http://172.16.1.27:8889/api/contact-centers/9f48899a-adf8-471b-aeee-e136fd3f39e7/recordings/
gvp.service-parameters/recordingclient.recdest
fixed,http://172.16.1.96/recordings
gvp.service-parameters/recordingclient.type
fixed,audio/mp3[/code]
But in metadata files, there is only info of Web Services.
[code]{"mediaFiles":[{"duration":"0","ivrprofile":"record","mediaDescriptor":{"path":"[b]http://172.16.1.96/recordings/[/b]2017-06-30T03%3A58%3A52Z_JB6CCUFA4P0UB9MRRBH5SS5II4000010_5001-00C10195-10002A44-00000001.mp3","storage":"webDAV"},"mediaId":"2017-06-30T03%3A58%3A52Z_JB6CCUFA4P0UB9MRRBH5SS5II4000010_5001-00C10195-10002A44-00000001.mp3","parameters":{"agentId":"5001","ani":"5002","callUuid":"JB6CCUFA4P0UB9MRRBH5SS5II4000010","connId":"006c02a4e4d3f01f","dateTime":"2017-06-30T03:58:52Z","dnis":"5001","id":"JB6CCUFA4P0UB9MRRBH5SS5II4000010_5002_5001_2017-06-30_03-58-52_","recordDN":"5001","sipsAppName":"hcmsip01"},"size":"0","startTime":"2017-06-30T03:58:40Z","stopTime":"2017-06-30T03:58:40Z","tenant":"Environment","type":"audio/mp3"}]}[/code]
Maybe, there is any options in MCP impact to this?
Thanks, Nhan
Offline nhannt
« Reply #11 on: July 07, 2017, 02:53:06 AM »
Hi cavagnaro,
After I changed IVR Profiles option:
gvp.general/service-type
gvp.general
service-type
record    #old value: voicexml
Metadata have been sent to Interaction Receiver, But it still response error code 202:
2017-07-07 09:38:39,700 metadatarecord DEBUG Could not find rp.speechminer_uri in record.
2017-07-07 09:38:39,700 metadatarecord DEBUG Could not find rp.speechminer_auth in record.
2017-07-07 09:38:39,700 process_metadata WARNING Could not find SM server info. Using default SM. H7RIE87ME140R1MTUF2DC2P5U8000009
2017-07-07 09:38:39,700 process_metadata DEBUG Sending to SM: H7RIE87ME140R1MTUF2DC2P5U8000009
2017-07-07 09:38:39,716 metadata_client DEBUG POST: http://172.16.1.21/interactionreceiver: Response Status: 202
2017-07-07 09:38:39,716 process_metadata DEBUG Removing metadata record:
2017-07-07 09:38:39,716 process_metadata DEBUG None
2017-07-07 09:38:39,716 process_metadata INFO 0 messages have been sent to HTCC.
Response in wireshark:
16315 848.926685000 172.16.1.27 172.16.1.21 HTTP 452 POST /interactionreceiver HTTP/1.1  (application/json)
16317 848.935156000 172.16.1.21 172.16.1.27 HTTP 395 HTTP/1.1 202 Accepted  (text/html)
Failed to process metadata. \r\n
ProgramId does not exist. External ID: H7RIE87ME140R1MTUF2DC2P5U8000008 not processed
Can you help me to check this issue?
Thanks, Nhan
« Reply #12 on: July 07, 2017, 03:08:05 AM »
What options you defined on the default IVR profile?
Offline nhannt
« Reply #13 on: July 07, 2017, 03:19:08 AM »
This is all options i have configured at IVR Profiles.
[gvp.context-services-authentication]
password = 3F54B4DDAD98B6EA912DA5282AFBF44E
username = default
[gvp.general]
service-type = record
[gvp.policy]
cti-allowed = false
outbound-call-allowed = true
transfer-allowed = true
use-same-gateway = always
[gvp.recording-certificates]
placeholder = 1
[gvp.service-parameters]
recordingclient.callrec_authorization = fixed,default:password
recordingclient.callrec_dest = fixed,http://172.16.1.27:8889/api/contact-centers/9f48899a-adf8-471b-aeee-e136fd3f39e7/recordings/
recordingclient.channels = 2
recordingclient.gvp.config.mpc.mp3.bitrate = fixed,16
recordingclient.gvp.config.msml.record.filenametemplate = fixed,$dateTime$_$callUuid$_$dnis$
recordingclient.httpauthorization = fixed,user:password
recordingclient.httpauthorization2 = fixed,default:password
recordingclient.recdest = fixed,http://172.16.1.96/recordings
recordingclient.rp.speechminer_auth = fixed,default:password
recordingclient.rp.speechminer_uri = fixed,http://172.16.1.21/interactionreceiver
recordingclient.type = fixed,audio/mp3
voicexml.gvp.appmodule = fixed,VXML-NG
[gvp.service-prerequisite]
initial-page-url = http://172.16.1.16:8080/Examples/src-gen/FullCallRecording.vxml
I also changed rpconfig.cfg in Proccesor
Add infor of SpeechMiner
[speechminer]
# Disable client certificate validation when connecting to SpeechMiner
# over HTTPS (0 == false)
post_uri=http://172.16.1.21/interactionreceiver
username=default
password=password
disable_ssl_certificate_validation = 1
Config new MSML use for recording:
[TServer]
contact = sip:172.16.1.91:5070
make-call-rfc3725-flow = 1
oos-check = 5
oos-force = 4
prefix = msml=
refer-enabled = false
ring-tone-on-make-call = false
service-type = msml
sip-hold-rfc3264 = true
sip-uri-params = gvp-tenant-id=record
subscription-id = Environment
Regard, Nhan
« Reply #14 on: July 07, 2017, 05:15:37 AM »
Is this profile really in use during the recording? Did you check what MCP is sending to the RPS?
