" /> Change the size of interaction tool bar buttons - Genesys CTI User Forum
Author Topic: Change the size of interaction tool bar buttons  (Read 2227 times)
Offline bharath
« on: November 01, 2017, 09:02:18 AM »
Can any one help how to increase the size of the interaction tool bar buttons.
(hold, end call button, etc.,)
thanks in advance.
Re: Change the size of interaction tool bar buttons
« Reply #1 on: November 01, 2017, 11:49:54 AM »
Can't, not by default, you will have to develop you own views with custom buttons
Offline bharath
« Reply #2 on: November 02, 2017, 02:14:27 PM »
Hi cavagnaro,
Thank you so much for your reply.
I would like to know is there any documentation for this. Thank you.
« Reply #3 on: November 02, 2017, 02:15:03 PM »
Docs.genesyslab.com as usual
Offline bharath
« Reply #4 on: November 06, 2017, 06:22:20 AM »
Thanks for your response.
Offline bharath
« Reply #5 on: November 10, 2017, 05:58:43 AM »
Hi Cavagnaro,
Am having another query.
Is there any way to move the buttons (end call button, hold call button) ? or It's not by default ?
Actually am new to Genesys. I would like to confirm with you.
Thanks in advance.
« Reply #6 on: November 10, 2017, 11:04:22 AM »
Yes, answer is not by default.
Any GUI modification would need customization on your side. I can't remember any serious app that allows to do such configurations...would be a nightmare for developers
Offline bharath
« Reply #7 on: November 10, 2017, 02:26:13 PM »
Thank you Cavagnaro
