" /> Display Name for Routing Point - Genesys CTI User Forum
Author Topic: Display Name for Routing Point  (Read 3118 times)
Offline bilge
« on: December 20, 2017, 10:30:49 AM »
Is there any way to show a name instead of number when a Cisco extension is dialed the RP number?
There is a SIP Trunk between Cisco and Genesys and a number on Cisco is routed to Genesys RP via this SIP Trunk.
We want to show a name on Cisco phone instead of RP number when the routed number is dialed.
Thank you,
Re: Display Name for Routing Point
« Reply #1 on: December 20, 2017, 11:05:37 AM »
Use p-asserted-identity
Offline bilge
« Reply #2 on: December 20, 2017, 11:47:32 AM »
Hi Kubig,
Thank you for your response. I tried to change the p-asserted-identity option for RP however it has effect on caller details. We need to add a display name for RP dialed from Cisco phones.
I guess we need to change To Header from To: <sip:RP@10.31.X.X> to To: "Call Center" <sip:RP@10.31.X.X>
Is there anything did i miss with this option?
Thank you,
« Reply #3 on: December 20, 2017, 12:49:52 PM »
In this case, it must be configured on Cisco level as it has nothing to do with Genesys.
Offline bilge
« Reply #4 on: December 20, 2017, 02:02:31 PM »
Thank you for your help.
Best Regards,
Offline Noufal
« Reply #5 on: February 15, 2018, 10:07:23 AM »
it  has to done from the Genesys .
« Reply #6 on: February 15, 2018, 11:58:24 AM »
[quote]it  has to done from the Genesys .[/quote]
??? What do you exactly mean?
Offline Noufal
« Reply #7 on: February 15, 2018, 12:04:04 PM »
be default there will be 3 values
Origin : inbound call to XXXXX
Queue : VQ/RP (here you ca edit)
Language :
« Reply #8 on: February 15, 2018, 12:07:59 PM »
I think you are talking about different topic
Offline Noufal
« Reply #9 on: February 15, 2018, 12:10:32 PM »
sorry i got mistaken..
