" /> 'Agent not in compatible state' login error - Genesys CTI User Forum
Author Topic: 'Agent not in compatible state' login error  (Read 2616 times)
Offline soporte_sd
« on: January 07, 2018, 06:47:29 PM »
when I try to login with WDE into an Avaya extension I get the following error message: Agent not in compatible state
I have tried with different agent ids and I get always the same error. I have restarted the Avaya station but the issue remains the same.
Have you ever faced the same issue? Any recommendation?
Thanks in advance.
Re: 'Agent not in compatible state' login error
« Reply #1 on: January 08, 2018, 10:55:50 AM »
Magic balls are broken
Logs, configurations done... You need to provide a better description and evidence, we just can't guess what have you done at your environment
