" /> Avaya CM integration with Genesys SIp Server - Genesys CTI User Forum
Author Topic: Avaya CM integration with Genesys SIp Server  (Read 2811 times)
Offline abhigupt
« on: March 12, 2018, 09:01:12 AM »
We have Avaya Media gateway and Avaya Call manager. We are looking to integrate this setup with Genesys Sip Server. Is it possible to create a sip trunk directly on Avaya Call manager(without purchasing Avaya Session Manager ) that can send calls to Genesys Sip Server.
Regards,
Abhinav
Offline voipy
Re: Avaya CM integration with Genesys SIp Server
« Reply #1 on: March 15, 2018, 01:12:38 PM »
I might be wrong here but I believe that AACM/Session Manager v6 upwards are not supported in a Genesys GVP/SIP Server 8.1 Environment.
However AACM with Genesys CTI is still supported.
Offline abhigupt
« Reply #2 on: March 15, 2018, 01:18:57 PM »
Thanks. All we are looking for is to have calls forward from AACM to Sip Server via a trunk group. I did checked with GTS and it is supported only if Sip server is above 8.1.x version....
