" /> Email interaction routed but cannot be handle - Genesys CTI User Forum
Author Topic: Email interaction routed but cannot be handle  (Read 1967 times)
Offline knromain
« on: May 15, 2018, 10:54:10 PM »
Hi All,
I have a problem with the implementation of genesys email
The interaction is good for the agent but, the toaster is not displayed and the agent is automatically put in not-ready state.
I find this in the logs.
18-05-15 23:18:52.110 [            42] ERROR e.InteractionManager - ESDKInteractionEvent Error: Type Genesyslab.Platform.Commons.Collections.KeyValueCollection is not supported by KeyValueCollection
System.ArgumentException: Type Genesyslab.Platform.Commons.Collections.KeyValueCollection is not supported by KeyValueCollection
  at Genesyslab.Enterprise.Commons.Collections.KeyValueCollection.Add(String key, Object value)
  at Genesyslab.Desktop.Modules.Core.Configurations.ConfigAttachedDataManager.CreateKeyValueCollection(String name)
  at Genesyslab.Desktop.Modules.Core.Configurations.ConfigAttachedDataManager.GetKeyValueCollection(String name)
  at Genesyslab.Desktop.Modules.Core.Configurations.ConfigAttachedDataManager.OverwriteOptions(String value)
  at Genesyslab.Desktop.Modules.Core.Model.Interactions.Interaction.OnRefreshAttachedData()
  at Genesyslab.Desktop.Modules.Core.Model.Interactions.Interaction.Initialize()
  at Genesyslab.Desktop.Modules.Core.Model.Interactions.InteractionManager.ESDKInteractionEvent(IEnvelope`1 tsp)
Offline knromain
Re: Email interaction routed but cannot be handle
« Reply #1 on: May 16, 2018, 07:57:42 AM »
Could someone give me a track on this error?
Offline vjicecool
« Reply #2 on: May 17, 2018, 09:59:43 PM »
Have you checked agent have the correct skills?
if desktop is keeping him and inactive something needs to look on the IWS app, this may not be related to Email server
Offline gen_den
« Reply #3 on: May 23, 2018, 07:24:18 AM »
You should try re-installing IW and also post URS and Interaction server logs for the same.
