" /> speechminer issue - Genesys CTI User Forum
Author Topic: speechminer issue  (Read 10080 times)
Offline Janis
Re: speechminer issue
« Reply #15 on: August 14, 2018, 12:23:14 PM »
What does speech miner Platform log say about Index?
Offline Janis
« Reply #16 on: August 14, 2018, 01:46:18 PM »
Here is the ULogger screenshot from fully working system where we just do not have screen recording. To make you sure that there is nothing to do with the error about Speech Miner UI.
https://failiem.lv/u/xxf8s7ze
« Last Edit: August 14, 2018, 01:48:32 PM by Janis »
« Reply #17 on: August 14, 2018, 01:58:26 PM »
Main problem is the SM is not able connect to the RCS which is necessary to playback the recordings - check your SM configuration on recording tab and also check whether RCS is available for SM
Offline Janis
« Reply #18 on: August 14, 2018, 02:07:46 PM »
It is not a problem at all :) We just do not have license for screen recording on this site.
I'm not asking for help this time. This is to help Nofaul to locate the reason of his problems.
« Reply #19 on: August 14, 2018, 03:07:17 PM »
My post was not answer to your post, it is reaction to Noufal's problem  ;D
Offline Janis
« Reply #20 on: August 14, 2018, 03:59:20 PM »
I’m quite sure that it isn’t Noufal’s problem either. List of calls is not coming from RCS. It comes from index. RCS can make playback problems when single call is selected in the list.
Offline mao_dzen
« Reply #21 on: August 27, 2018, 04:07:14 AM »
Can you send:
1. versions of MCP and GIR
2. Screen of SM UI (yeah it will show nothing)
3. ID of any sample call and matching logs including MCP and SM (debug level)
4. check if CLR enabled
5. SM config details
for the first look RPS able to post to IR so SM should show this call in UI. The most popular error with that, related to CLR.
About indexer: it means that this particular indexer is in passive state in case if you have two or more. You cannot do anything here :) if its only one - the same. Indexer not running all the time.
If you suspect any troubles with Index just stop SM and empty index folder.
« Last Edit: August 27, 2018, 09:50:11 AM by mao_dzen »
Offline Noufal
« Reply #22 on: August 28, 2018, 06:08:21 AM »
Thank you  for your kind response , it is been long pending issue so i request you to support me on remotely as i hope you can fix
could you check it in remotely
« Reply #23 on: August 28, 2018, 07:41:06 AM »
Make a test (make an inbound call which will be recorded) and then post all logs (MCP, RPS, IRWS, all SpeechMiner submodules - web,index,interaction receiver,etc., RCS) covering your test
