" /> chat reason codes definitions - Genesys CTI User Forum
Author Topic: chat reason codes definitions  (Read 2898 times)
Offline CASANOVA
« on: February 08, 2019, 06:15:54 AM »
can anybody help me with the exact definitions of the below chat reason codes.
reason code = '0' left
reason code = '1' left with request to close if no agents
reason code = '2' left with request to close forcely
reason code = '3' left due to disconnect
reason code = '4' removed by other party
reason code = '5' removed by the server
reason code = '6' removed due to bad secure key
Re: chat reason codes definitions
« Reply #1 on: February 08, 2019, 12:18:33 PM »
???  What do you mean? The definitions are there in your post
Put them in the context of a chat interaction
Offline CASANOVA
« Reply #2 on: February 09, 2019, 12:19:37 AM »
Sorry, i mean to say what kind of scenarios these reason codes will generate.
Reason codes 1,2 & 3 looks almost similar. I am unable to understand the same.
Apologies my queries has confused you.
Thanks.
Offline jamesmurphyau
« Reply #3 on: February 09, 2019, 09:34:30 AM »
Where are you seeing these reason codes? Which event is it in, and exactly where in the event is it (ie UserData? Extensions? What's the key)
« Reply #4 on: February 09, 2019, 09:40:03 AM »
Or are you seeing these values in a reporting system? (Pulse, CC Pulse, Infomart?).. if so, which report and which field
Offline CASANOVA
« Reply #5 on: February 10, 2019, 05:07:03 AM »
These reason codes are from chat server logs.
