" /> TOMCAT is crashing frequently - Genesys CTI User Forum
Author Topic: TOMCAT is crashing frequently  (Read 3555 times)
Offline CASANOVA
« on: March 20, 2019, 09:35:58 AM »
Hi All,
Need suggestion on the the mentioned subject.
We have GSS in our environment which is bases on Apache Tomcat. We could see[b][i] "SEVERE: Unexpected death of background thread ContainerBackgroundProcessor[StandardEngine[Catalina]]java.lang.OutOfMemoryError: Java heap space"[/i][/b] frequently.
We have deployed the same on two hosts. one is running with java version "1.7.0_67" in one host and java Version 7.0.55  in another host.
There is no setenv.bat in the installed directory.
Could anyone please suggest how can we configure java memory.
Thank you
Re: TOMCAT is crashing frequently
« Reply #1 on: March 20, 2019, 09:48:35 AM »
Update/Add Xms/Xmx parameters
Offline CASANOVA
« Reply #2 on: March 20, 2019, 12:50:20 PM »
[quote author=Kubig link=topic=11291.msg51425#msg51425 date=1553075315]
Thanks for your response Kubig.
It is a windows enviroment actually. Creating a setenv.bat with java parameters will be enough ?
Thank you.
Offline CASANOVA
« Reply #3 on: March 20, 2019, 12:55:25 PM »
Also this is for Genesys SurveySolution(GSS)
there are no catalina.bat ot steneve. bat file presetn by default. Bin follder contains only Tomcat7_GSS_Http.exe files and bootstrap.jar file.Creating a batch file with java arguments will be ok ?
« Reply #4 on: March 22, 2019, 01:25:02 AM »
Check Tomcat documentation. There tons of posts on the internet. There are several ways.
You need to see how your app is started
Offline genesysnoob
« Reply #5 on: March 30, 2019, 02:16:08 PM »
have you considered increasing java memory?
