" /> WWE My Agents virtual AG display - Genesys CTI User Forum
Author Topic: WWE My Agents virtual AG display  (Read 1985 times)
Offline marmota
« on: June 19, 2020, 10:26:43 AM »
Hi all,
using My Agents at WWE SV can see only his/her static AG - virtual AGs are not displayed in the list. Any clues how to fix?
Thanks in advance!
« Last Edit: June 20, 2020, 07:41:38 AM by marmota »
Re: WWE My Agents virtual AG display
« Reply #1 on: June 19, 2020, 02:11:50 PM »
In what part of WWE application? Try to be more specific in your issue description
Offline marmota
« Reply #2 on: June 20, 2020, 07:40:42 AM »
Well, there is only one "My Agents" view at WWE - not sure how to be more specific =)
Click on Top-Right menu of WWE -> My Agents.
In My Agents view there is a drop-down list with AGs that are assigned to SV. Virtual AGs are not displayed in the list.
« Reply #3 on: June 20, 2020, 02:50:11 PM »
You mean the groups? Or the agents?
The agents are not visible because they are built dynamically by Stat server not Cfgserver, there is like a query to be run based on your script.
If you are talking about the Groups... Maybe permissions at Cfgserver level?
Offline marmota
« Reply #4 on: June 20, 2020, 03:10:56 PM »
Yep, Agent Groups. Unfortunatelly haven't found anything at configuration - digged all the docs...
These virtual groups are configured absolutely the same way as regular groups (well, except the rule how agents are included to the group) - I mean permissions etc. But regular groups are displayed, and virtual are not.
« Reply #5 on: June 21, 2020, 04:24:11 PM »
What version of WWE is in use? I would recommend to use the latest version of WWE or at least version 8.5.202.50+
Offline marmota
« Reply #6 on: June 22, 2020, 06:20:32 AM »
Hi! We use fresh one 8.5.202.57
