" /> CCPulse - Genesys CTI User Forum
Author Topic: CCPulse  (Read 14519 times)
Lorenzo
CCPulse
One of our customers is rebooting its Genesys Reporting servers (on which StatServer_CCP is located) every Sunday night. As supervisors arrive on Monday morning they launch the CCPulse application but do not see the calls which reached the Call Center until they opened the application.
Is there any possibility to launch CCPulse (and open the Workspaces) on a particular PC after the reboot of the StatServer in order not to lose these calls on the real Time view ?
Thanks in advance for your suggestions !
Tony Tillyer
CCPulse
  • You could try this (I'll assume it's a Windowsased Server);
    Install CCPulse on the *Server*
    Create a Batch File on the *Server*, called CCPULSE.bat, with the following information:
    <type in the full path of CCPulse here...>CallCenter.exe user <username> pwd <password> app <CCPulse CME application name> ws <Workspace Name>
    Save the Batch file in your StartUp Folder of the *Server*.
    Each time the Server is restarted, CCPulse will run, using the <username>, <password> and <app> information, then open the specified <workspace>.
    It *should* work!
    Tony Tillyer
    CCPulse
  • An afterthought...
    You will need to map a drive to your Workspace File, as it is reliant on the information for CCPulse in CME.
    What I mean is, CCPulse will have a path defined in CME and you need your *Server* version of CCPulse to emulate the path, as defined in CCPulse.
    For instance, if your CCPulse CME settings are defined (for a Desktop PC) as having the CCPulse .stg files in:
    C:/CCPulse/Workspaces/Workspaces.stg
    C:/CCPulse/Workspaces/Templates.stg
    ...etc...
    ...You need to ensure that your *Server* .stg files are in the same location, from the *Server* when it reboots. This may mean adding an extra line in the .BAT file to map a drive correctly, or to ensure that your .stg files are in the right place when the Server reboots.
    I hope this helps?
    Lorenzo
    CCPulse
  • I have created the batch with the following info :
    C:\GCTI\CCPulse+\CallCenter.exe user genesys pwd genesys app CCPulse_Local ws Test
    When I launch the batch file manually from the server without simulating a reboot for the moment, I get the first popup window from CCpulse but no info are filled in : no user, no password etc...
    Did I miss something ?
    Dave
    CCPulse
  • first line of bat file must be
    SET CCPULSE_ACCESS=COMMAND_LINE
    Lorenzo
    CCPulse
  • Great !!
    Many thanks !!
    Leotah
    CCPulse
  • How long have you been working with CCPulse... I am very new to this so I am trying to learn as much as I can...
    Mr.Leotah
    Jeff
    CCPulse
  • I was always frustrated with the fact that we need to have CCP open at all times to get the right stats. Is there a way out of it? Would changing TimeProfile fix it?
    Tony Tillyer
    CCPulse
  • I'm not sure that you would want all available statistics running all of the time. One of my sites has 203 different statistics available in the StatServer/DMA but only 15 are actually in use...
    As an addendum to the advice on this thread... To make absolutely sure that your statistics are running 24 hours, if you are using Windoze, you could set up an ATCommand to ensure CCPulse is shut down and run up again on the StatServer Server itself, every day, at 00:01.
