" /> DB server is disconnected from the database - Genesys CTI User Forum
Author Topic: DB server is disconnected from the database  (Read 5067 times)
Offline Gaia
« on: April 21, 2022, 10:38:13 AM »
Hi all,
I hope this issue isn't out of scope  ???
I am facing a problem connecting to  Icon DB
log DB server
+0000  Could not connect to SQL Server using SQL Server Native Client 11.0. Attemting default MS SQL Server driver...
+0000  odbcerr: [Microsoft][ODBC Driver Manager] Data source name not found and no default driver specified
+0000  MSG_ERROR status='dbNotOpened' msg='[Microsoft][ODBC Driver Manager] Data source name not found and no default driver specified '
Log ICON
" Std 04502 Cannot connect to CFG 'DBServer_icon' at host 'S00STE024', port 1436, reason 'DB server is disconnected from the database'"
the interaction concentrator version is 8.1.514.56 on Windows Server 2019 and DB MS SQL Server 2016
I tried with ODBC Driver 11 for SQL Server and ODBC Driver 13 for SQL , the error message is the same on DBServer
I tested the connexion with ODBC Data Source Administator and the connexion was succesful with both version of drivers
What did i miss ?
Br
Re: DB server is disconnected from the database
« Reply #1 on: April 21, 2022, 01:48:02 PM »
Try to connect from Windows ODBC settings, it is good to discard connectivity/configuration issues
Offline Gaia
« Reply #2 on: April 21, 2022, 02:41:21 PM »
It's working from Windows ODBC settings , I created DSN and tested the connexion
Br,
« Reply #3 on: April 21, 2022, 03:42:51 PM »
Can you post DAP and full DBServer log?
Offline Gaia
« Reply #4 on: April 22, 2022, 09:20:23 AM »
hi,
this is dbserver log
Genesys Database Server, Version:'8.5.100.12'
Copyright (c) 1997-2021 Genesys Telecommunications Labs, Inc.
Component versions:
Commonlib:        8.5.100.87 C2
Loglib:          8.5.100.56
Gmessagelib:      8.5.100.25
GServicelib:      8.5.100.42
Mngmlib:          8.5.100.10
Confservlib:      8.5.100.45
Lcalib:          8.5.100.38
Build platform:  i686-winnt-vs12-64
Application name: DBServer_icon
Application type: RealDBServer (46)
Command line:    multiserver.exe -service DBServer64 -app DBServer_icon -host S00STE001 -port 2020 -sstart
Host name:        MYHOST
DST:              TZ = 1, timeb = 1
Time zone:        -3600, Romance Standard Time, Romance Daylight Time
UTC time:        2022-04-22T09:08:28.662
Local time:      2022-04-22T11:08:28.662
Start time (UTC): 2022-04-22T09:08:28
Running time:    0:00:00:00
Host info:      Windows Server 2019 Standard (17763.rs5_release.180914-1434.2803)
File:            (1) C:\GCTI\Logs\DBServer_icon\DBServer_icon.20220422_110828_663.log
11:08:28.662 Trc 04112 The Log Output of type 'C:\GCTI\Logs\DBServer_icon\DBServer_icon' has been created and opened
11:08:28.662 Trc 04110 Option 'verbose' has been set to the value 'all'
11:08:28.662 Trc 04110 Option 'buffering' has been set to the value 'yes'
11:08:28.662 Trc 04110 Option 'expire' has been set to the value '5 file'
11:08:28.662 Trc 04110 Option 'segment' has been set to the value '2000'
11:08:28.662 Trc 04110 Option 'spool' has been set to the value ''
11:08:28.662 Trc 04110 Option 'snapshot' has been set to the value ''
11:08:28.662 Trc 04110 Option 'recovery-timeout' has been set to the value '30'
11:08:28.662 Trc 04110 Option 'keep-startup-file' has been set to the value 'no'
11:08:28.662 Trc 04110 Option 'MessageFile' has been set to the value 'RealDBServer.lms'
11:08:28.662 Trc 04110 Option 'time-format' has been set to the value 'time'
11:08:28.662 Trc 04110 Option 'time-convert' has been set to the value 'local'
11:08:28.662 Trc 04110 Option 'message-format' has been set to the value 'short'
11:08:28.662 Trc 04110 Option 'memory-storage-size' has been set to the value '2 Mb'
11:08:28.662 Trc 04110 Option 'compatible-output-priority' has been set to the value 'no'
11:08:28.662 Trc 04110 Option 'print-attributes' has been set to the value 'no'
11:08:28.662 Trc 04110 Option 'check-point' has been set to the value '1'
11:08:28.662 Trc 04110 Option 'memory' has been set to the value ''
11:08:28.662 Trc 04113 The Log Output of type 'stderr' has been closed and deleted
11:08:28.662 Trc 06084 Configuration option set: 'dbserver':'management-port' = '4041'
11:08:28.662 Trc 06085 Configuration option set to default value: 'dbserver':'dbprocesses_per_client' = '1'
11:08:28.662 Trc 06084 Configuration option set: 'dbserver':'dbprocess_name' = './dbclient_sybase'
11:08:28.662 Trc 06085 Configuration option set to default value: 'dbserver':'oracle_name' = './dbclient_oracle'
11:08:28.662 Trc 06085 Configuration option set to default value: 'dbserver':'informix_name' = './dbclient_informix'
11:08:28.662 Trc 06085 Configuration option set to default value: 'dbserver':'msql_name' = './dbclient_msql'
11:08:28.662 Trc 06085 Configuration option set to default value: 'dbserver':'sybase_name' = './dbclient_sybase'
11:08:28.662 Trc 06085 Configuration option set to default value: 'dbserver':'postgre_name' = './dbclient_postgre'
11:08:28.662 Trc 06085 Configuration option set to default value: 'dbserver':'connect_break_time' = '1200'
11:08:28.662 Trc 06085 Configuration option set to default value: 'dbserver':'tran_batch_mode' = '0'
11:08:28.662 Trc 06085 Configuration option set to default value: 'dbserver':'db2_name' = './dbclient_db2'
Open LCALayer on port=4999
LCA Library version 8.5.100.38
11:08:28.662 Std 05060 Application started
Opening listeners...
Port id 'default':
Open server port: = (
  "protocol" = "addp"
  "addp-timeout" = "0"
  "addp-remote-timeout" = "0"
  "addp-trace" = "off"
  "name" = "DBServer_icon"
  "server-type" = "46"
  "backlog" = "5"
  "port" = "1436"
11:08:29.687 Std 04525 Port 1436 opened for listening
Updating primary/backup config server info 99 0
Primary config server (dbid)(host)(port): (99)(S00STE001)(2020)
Error while retrieving backup config server info.
LCALayer: REventRegistered on LCA...
LCALayer: The local host is under control of Management Layer. SCS 'SCS' has connected to the LCA from the host '' on the socket 888.
GServer: new_client: fd=600, found server=596
11:08:43.151 Trc 04521 New client 54141 connected from '192.168.103.99'
11:08:43.167 Dbg 10745 'App: 192.168.103.99:54141' registered; protocol version '1.4' id '1'
11:08:43.167 Dbg 10734 Send message 'MSG_EXTPACKETS' to 'App: 1', request id '0'
11:08:43.167 Dbg 10750 Start client request, dbprocesses per client '1'
11:08:43.167 Dbg 10734 Send message 'MSG_CLIENTSTARTED' to 'App: 1', request id '2'
11:08:43.214 Std 05022 Process './dbclient_msql' started
GServer: new_client: fd=624, found server=608
11:08:43.245 Trc 04521 New client 54143 connected from '127.0.0.1'
11:08:43.245 Dbg 10745 './dbclient_msql' registered; protocol version '1.4' id '1.1'
11:08:43.245 Dbg 10734 Send message 'MSG_OPENDB' to 'MS SQL: 1.1', request id '3'
11:08:43.245 Dbg 10734 Send message 'MSG_EXTPACKETS' to 'App (ICON_CFG,MYHOST,4030)', request id '0'
11:08:43.245 Dbg 10734 Send message 'MSG_EXTPACKET' to 'MS SQL: 1.1', request id '0'
11:08:43.245 Dbg 10743 'MS SQL: 1.1' is spare
11:08:43.573 Dbg 10739 ODBC: id='1.1' req='-1'
DBClient ODBC, Copyright (c) 1997-2021 Genesys Telecommunications Labs, Inc.
All Rights Reserved
Db Client version:        8.5.101.44
DB Common part version:    8.5.101.44
Vendor supported versions: "ODBC"
Process ID:                2996
Build on 'i686-winnt-vs12-64'
+0015  Connection to multiserver created, host 'localhost', port '54142', socket '248'
+0015  MSG_STARTDB status='DBM_SUCCESS'
ODBC: id='1.1' req='3' Protocols versions: dbclient='00010004' dbserver='00010004' dblib='00010004'
+0000  Database Access Point in TKVList:
+0000    section "default":
+0000      "dbengine" = "mssql"
+0000      "dbserver" = "DBHOST\SQL014"
+0000      "dbname" = "IDBCFG"
+0000      "username" = "genesys"
+0000      "password" = "***"
+0000      "dbcase" = "any"
+0000      "db-request-timeout" = "10"
+0000    section "dbclient":
+0000      "utf8-ucs2" = "true"
+0000      "max-binding-memory" = 250
+0000  0000023F52989640,hDBC=1388669328,1388669328
+0000  Open DB: username = 'genesys', database = 'IDBCFG', dbserver = 'DBHOST\SQL014'
+0235  Could not connect to SQL Server using SQL Server Native Client 11.0. Attemting default MS SQL Server driver...
+0328  odbcerr: [Microsoft][ODBC SQL Server Driver]Dialog failed
+0328  MSG_ERROR status='dbNotOpened' msg='[Microsoft][ODBC SQL Server Driver]Dialog failed '
11:08:43.573 Dbg 10749 Forwarding response '3.1' from 'MS SQL: 1.1' to 'App (ICON_CFG,MYHOST,4030)'
11:08:43.573 Dbg 10734 Send message 'MSG_DISCONNECTED' to 'App (ICON_CFG,MYHOST,4030)', request id '-1'
11:08:43.573 Dbg 10734 Send message 'MSG_DISCONNECTED' to 'MS SQL: 1.1', request id '-1'
  /Statistics
    name                      = MS SQL: 1.1
    app_name                  = App (ICON_CFG,MYHOST,4030)
    req_rcvd                  = 5
    req_sent                  = 3
    data_rcvd                = 1620
    data_sent                = 386
    msg_error                = 1
    msg_log                  = 1
Client MS SQL: 1.1 is being closed. Current numofclients=0
Listener (port id = internal-0-0 fd = 608) is being closed. Checking for clients on listener...
Listener with port id = internal-0-0 has been closed and deleted from list of current ports. Number of db app connections affected: 0
Client App (ICON_CFG,MYHOST,4030) is being closed. Current numofclients=1
br,
« Reply #5 on: April 22, 2022, 09:47:03 AM »
It seems your MS ODBC Driver configuration is not valid - try to check connectivity via ODBC apart Genesys apps
Offline Gaia
« Reply #6 on: April 22, 2022, 10:05:27 AM »
Hi Kubig
Thank you for the rely
I tested with ODBC Data Administrator and the connexion was suucesful.
I don't understand this ==> Could not connect to SQL Server using SQL Server Native Client 11.0. Attemting default MS SQL Server driver...
In my System DNS i specified ODBC driver 17 for SQL Server
Br,
Offline catanirex
« Reply #7 on: April 22, 2022, 10:44:32 AM »
Looks like you are using a SQL server instance: dbserver = 'DBHOST\SQL014
Try to modify your DAP, and add ',<portnbr> in the end of option DBMS Name
In you case dbserver = 'DBHOST\SQL014,1433
Or the port you actually are using!
Offline Gaia
« Reply #8 on: April 22, 2022, 10:54:21 AM »
+0000  Open DB: username = 'genesys', database = 'DBCFG', dbserver = 'DBHOST\SQL014,1436'
+0062  [b]Could not connect to SQL Server using SQL Server Native Client 11.0. Attemting default MS SQL Server driver...[/b]
+0078  odbcerr: [Microsoft][ODBC SQL Server Driver]Dialog failed
+0078  MSG_ERROR status='dbNotOpened' msg='[Microsoft][ODBC SQL Server Driver]Dialog failed '
« Reply #9 on: April 22, 2022, 01:35:28 PM »
Is the firewall OK for that port?
Post please you DAP conf
Offline Gaia
« Reply #10 on: April 22, 2022, 02:29:53 PM »
I tested 3 configuration
DBHOST\SQL014,1436
DBHOST\SQL014
DBHOST,1436
We have 2 db on server DBHOST one on 1433 , 1436
Offline Gaia
« Reply #11 on: April 22, 2022, 02:52:06 PM »
I think that the problem is that  I am using the database password and not the password of the schema DBCFG.
I will test this later when our DBA send the password  ::) ::)
« Reply #12 on: April 22, 2022, 03:24:28 PM »
Also check the bit version of running apps and installed/configured ODBC
« Reply #13 on: April 22, 2022, 03:34:37 PM »
[quote author=Gaia link=topic=12282.msg54793#msg54793 date=1650637793]
DBHOST\SQL014,1436
DBHOST\SQL014
DBHOST,1436
and on which one is your ICON DB created?
As per your password comment...you already tested ODBC so wouldn't make sense that you are using a new user/password
That is why I am asking your DAP conf, please help us help you by providing info as requested ;)
Offline Gaia
« Reply #14 on: April 22, 2022, 05:53:56 PM »
It's working with this configuration
DBMS = DBHOST\SQL014
My DBA send me the right passeword
My test was successful because there was 2 db on the same serveur. and the login was the same.
When I tested connectivity with ODBC data source administrator, I idid'nt change the option "change the default database".
