" /> Latin letters wrong display - Genesys CTI User Forum
Author Topic: Latin letters wrong display  (Read 2215 times)
Offline zillisow
« on: May 05, 2022, 12:42:05 PM »
Hi everybody,
I live in France and am working in a french environnment.
My issue is quiet simple.
I have installed a config server (8.5.101.89) on a Linux VM (Red Hat Enterprise release 7.9).
The config database that the confg server use in installed on a SQL Server 2016 running on Windows 2016.
We use a odbc client on the linux VM to perform the connection : Microsoft ODBC Driver 17 for SQL Server
However, when the installation is over, on CME (or GA or GAX), we have a wrong display of character:
"é" - é
"Ã " - à
"û" - ù
"ê" - ê
"è" - è
"â" - â
"’" - ' (apostrophe)
I have performed a test, by installing the same version of config server on a Windows VM, using the same config database, and everything is OK.
« Last Edit: May 05, 2022, 12:44:14 PM by zillisow »
Re: Latin letters wrong display
« Reply #1 on: May 05, 2022, 01:41:04 PM »
Did you configure locale on Linux system? If not, check what is the current value and change it to the proper one - I assume there is a conflict between locale and used encoding by Configuration Server. Also check whether you have enabled multi-language support on confserv level.
Offline zillisow
« Reply #2 on: May 05, 2022, 02:00:14 PM »
Thanks for your reply.
We have checked all these parameters.
All locale parameters on Linux are UTF-8
e.g LANG=fr_FR.UTF-8, LC_CTYPE="fr_FR.UTF-8", etc...
Also, the applicative user which starts the ./confserv is set with LANG=fr_FR.UTF-8
« Reply #3 on: May 05, 2022, 02:05:31 PM »
Did you also configure GA/GAX to support your encoding character set?
Offline zillisow
« Reply #4 on: May 05, 2022, 02:25:59 PM »
No, I didn't.
Note that when I use the config server installed on a Windows VM, everything is fine.
PS: If ever, how do I configure the parameters you are talking about on GA/GAX?
« Reply #5 on: May 05, 2022, 02:41:08 PM »
GA - web.config
GAX - JVM parameter -Dfile.encoding
Offline zillisow
« Reply #6 on: May 06, 2022, 01:45:44 PM »
Hello everyone,
an official repsonse from Genesys:
"Non-Ascii characters are NOT supported by any version of Genesys on Linux. There is no plan/priority to address that, suggest customer to install DbServer on Windows."
This is good to know.
« Reply #7 on: May 06, 2022, 02:47:19 PM »
Wait what? We have Genesys in full Linux with Brazilian characters working fine, we did adjustments to Encoding but that was it.
Or maybe yours is something different?
Offline zillisow
« Reply #8 on: May 07, 2022, 02:11:03 PM »
We are using Genesys with a SQL database installed on a Windows Server.
Maybe that's the difference.
Offline hsujdik
« Reply #9 on: May 08, 2022, 12:26:56 AM »
Check the collation of your SQL database. It matters for accentuation. Try Latin1_CI_AS
