" /> SIP audiocodes Handset 420HD configuration - Genesys CTI User Forum
Author Topic: SIP audiocodes Handset 420HD configuration  (Read 1676 times)
Offline PFCCWA
« on: May 06, 2022, 09:27:10 AM »
do anyone have a sample config file for setting up a SIP.Audiocodes/420HD phones?
we are using admin guides from genesys support site but the handset is not being registered.
not sure if we are even doing it correctly at the moment.
thanks
Re: SIP audiocodes Handset 420HD configuration
« Reply #1 on: May 06, 2022, 02:47:52 PM »
Not being registered? That is basic one...what error does SIP logs show?
Offline Marreco
« Reply #2 on: May 06, 2022, 07:14:03 PM »
This information will normally be obtained from the Audiocodes support document.
https://www.audiocodes.com/media/13482/400hd-series-ip-phone-administrators-manual-ver-2216.pdf
https://www.audiocodes.com/media/13484/420hd-ip-phone-users-manual-ver-2216.pdf
I used the 420HD model some time ago in a client where it was registered in Sip Proxy Genesys. I share the file, see if it helps you.
https://1drv.ms/u/s!AnGh2OGtY8gPmaxMQPJD_eefk8wx0w?e=h92AZz
I recommend extracting the important information and feeding it into the file of your firmware version that you are using, as it will probably be more current and will have more features, in addition to what I am sharing, it is configuring the device with the language in Portuguese.
Test before putting it into production.
[quote author=PFCCWA link=topic=12295.msg54860#msg54860 date=1651829230]
thanks
« Last Edit: May 06, 2022, 07:18:45 PM by Marreco »
