" /> Composer - Genesys CTI User Forum
Author Topic: Composer  (Read 1151 times)
Offline RifaiBedir
Composer
« on: March 17, 2023, 07:56:22 AM »
Is it possible using Jquey library in Composer?
I could not find anything.
Offline hsujdik
Re: Composer
« Reply #1 on: March 18, 2023, 11:20:32 PM »
Hello Rifai,
Technically, you could load anything that Spidermonkey 1.7 JavaScript engine would support (so, maybe very old versions of jQuery would be supported) but I don't see a point of using it. jQuery was made for webpages and DOM manipulation, and not to be embedded on SCXML or VXML. Is there any specific requirement that you are relying on jQuery to do?
