" /> HISTORY ( Dropped ) message in URS logs - Genesys CTI User Forum
Author Topic: HISTORY ( Dropped ) message in URS logs  (Read 1008 times)
Offline Gef Buneri
  • Madness is just a point of view.
« on: August 31, 2023, 10:58:23 AM »
URS 8.1.4 SipServer 8.1.1
I noticed many calls that show the message HISTORY ( Dropped ) in the logs when they are already routed to an Agent (using WDE). Where should I check, for troubleshooting?
12:07:48.789_T_I_006d0357ccb5d47f [14:0c] EventTreatmentApplied is received for ts sipserver[SERVERNAME] (thisdn=[DNUMBER])
    _B_I_006d0357ccb5d47f [14:21] treatment applied===========>TREATMENT_APPLIED
    _B_I_006d0357ccb5d47f [14:21] call states: s=7 d=5 t=3
12:07:48.789_M_I_006d0357ccb5d47f [10:1f] pulse for one call
12:07:48.828_G_I_ [01:0b] look for hanged interactions: 85 at all now (1 cpu, -1 ntfs, 4 wfnc, [603 2004 0] evs, 35 rr)
    _G_W_006d0357ccb5d42e [01:0b] call waits too long (111 sec)
12:07:48.828 Std 21007 Attention! interaction 006d0357ccb5d42e is removed without processing
12:07:48.828_I_I_006d0357ccb5d42e [01:08] call (2573808-4454cd0) deleting truly
006d0357ccb5d42e, 08/31/23@12:07:48.828, 10265(sipserver) -> @ [dropped dumb  3 0 0 0], tms: 111655= (N)111655 + (T)0 + (X)0 + (S)0 + (W)0 + (F)0 + (R)0, trg:
CALL (006d0357ccb5d42e) HISTORY ( Dropped ):
    _G_W_006d0357ccb5d338 [01:0b] call waits too long (109 sec)
12:07:48.828 Std 21007 Attention! interaction 006d0357ccb5d338 is removed without processing
12:07:48.828_I_I_006d0357ccb5d338 [01:08] call (2573809-5c3b408) deleting truly
006d0357ccb5d338, 08/31/23@12:07:48.829, 10169(sipserver) -> @ [dropped dumb  4 0 0 0], tms: 109681= (N)109681 + (T)0 + (X)0 + (S)0 + (W)0 + (F)0 + (R)0, trg:
CALL (006d0357ccb5d338) HISTORY ( Dropped ):
    _G_W_006d0357ccb5d31c [01:0b] call waits too long (99 sec)
12:07:48.829 Std 21007 Attention! interaction 006d0357ccb5d31c is removed without processing
12:07:48.829_I_I_006d0357ccb5d31c [01:08] call (2573822-4270510) deleting truly
006d0357ccb5d31c, 08/31/23@12:07:48.829, 10118(sipserver) -> @ [dropped dumb  3 0 0 0], tms: 99419= (N)99419 + (T)0 + (X)0 + (S)0 + (W)0 + (F)0 + (R)0, trg:
CALL (006d0357ccb5d31c) HISTORY ( Dropped ):
    _G_W_006d0357ccb5d362 [01:0b] call waits too long (74 sec)
12:07:48.829 Std 21007 Attention! interaction 006d0357ccb5d362 is removed without processing
12:07:48.829_I_I_006d0357ccb5d362 [01:08] call (2573839-5c43278) deleting truly
006d0357ccb5d362, 08/31/23@12:07:48.829, 10219(sipserver) -> @ [dropped dumb  4 0 0 0], tms: 74633= (N)74633 + (T)0 + (X)0 + (S)0 + (W)0 + (F)0 + (R)0, trg:
CALL (006d0357ccb5d362) HISTORY ( Dropped ):
12:07:48.829_G_I_ [01:0b] there are 81 calls in progress now
Regards,
Gef
Re: HISTORY ( Dropped ) message in URS logs
« Reply #1 on: August 31, 2023, 06:15:47 PM »
Why you say it was routed to an agent?
Enviado de meu SM-S918B usando o Tapatalk
Offline Gef Buneri
« Reply #2 on: September 01, 2023, 07:51:38 AM »
Hi Cav. The URS selects the target and tries to route there, I see urs calling a strategy loaded on the extensions dn ringing state, router tries to connect call and agent (add DN sipserver [EXTENSION] <[EXTENSION]@[SWITCHNAME]>), then it drops it with that message. On his side, the agent doesn't see anything, nor ringing. Same agents work with other calls, so doesn't look as an agent issue.
======== DN Information =======
Number [EXTENSIONDNNUMBER]
Access [EXTENSIONDNNUMBER]
Agent [AGENTID]
Place [EXTENSIONDNNUMBER]
Login [AGENTID]
Switch [SWITCHNAME]
Type 1
============== Target Information =================
Name    < [AGENTGROUPNAME >
Location < [STATSERVERNAME] >
Type    < GA >
STATE MAPPING -  < ##state >:
Stat Value: DN info OK
Modelling  : NA
« Reply #3 on: September 01, 2023, 08:41:08 AM »
Check Sip server. I do see it as a lack of communication between agent and Sip server
TLib started to try something, but didn't reach it's destination.
Offline Gef Buneri
« Reply #4 on: September 01, 2023, 10:28:21 AM »
Any clue here?
SIP logs excerpt:
[url=https://wetransfer.com/downloads/5519df893980a0afab22a4b8984baef920230901102717/693bf42a53730c019c340a85e52d91fd20230901102739/5bfa66?trk=TRN_TDL_01&utm_campaign=TRN_TDL_01&utm_medium=email&utm_source=sendgrid]https://wetransfer.com/downloads/5519df893980a0afab22a4b8984baef920230901102717/693bf42a53730c019c340a85e52d91fd20230901102739/5bfa66?trk=TRN_TDL_01&utm_campaign=TRN_TDL_01&utm_medium=email&utm_source=sendgrid[/url]
