" /> Call Center testing - Genesys CTI User Forum
Author Topic: Call Center testing  (Read 6753 times)
alan
Call Center testing
I'm looking to do some testing for my new Genesys install. Do you know anybody that can simulate call center busy hours, real life traffic????
Victor
Call Center testing
  • Well, there is always a simulator by Genesys you can use. There are also a lot of load generators on the market you can look into, depending on how serious you are.
    I would suggest starting with the simulator since you would be able to accomplish a lot of the testing with it.
    Hope it helped,
    Richard
    Call Center testing
  • If you want to do end to end testing try to get Hammer IT for load testing and some Call Generators from Ameritec for example. They support E1. T1 and Analog interfaces. Of course you can use a Lucent or M1 simulator for testing as well.
    Offline reign.call
    Re: Call Center testing
    « Reply #3 on: April 08, 2009, 02:45:46 PM »
  • Drive Hiring Performance Improvement with our Call Center Hiring and Assessment ... The right employees are the key to success in any contact or call center. The Call Center Skills Test, from which a four-page report is provided to the client, is ideal for evaluating the potential of candidates,[url=http://www.inin.com]Call Center Software[/url]...
    Offline genesC
    « Reply #4 on: January 08, 2011, 02:05:07 AM »
  • An excellent performance is the key to succeed in the call center career. All agents must be witty and smart especially in communicating. They should be very competitive as they are battling with thousands of applicants.
    « Last Edit: January 13, 2011, 04:30:13 AM by genesC »
    Offline ronaldgrice
      • Telemarketing Companies - Top Telemarketing Call Center Services
    « Reply #5 on: August 04, 2012, 01:50:05 AM »
  • [quote author=Richard link=topic=138.msg1844#msg1844 date=0]
    Well I agree with him. I would have suggest so. Hopefully this will help you. Go on & good luck.
    Ronald T. Grice
    TMC - [url=http://www.telemarketingconsultant.com/]Call Center[/url] Consultant
