" /> Treatment usage with SelectDN and SuspsendForDN - Genesys CTI User Forum
Author Topic: Treatment usage with SelectDN and SuspsendForDN  (Read 3025 times)
Timmy2000
Dear all,
in my search for Genesys grail, I found myself using SelectDN and SuspendForDN quite a lot. Unfortunately for me, I cannot figure out a way to fine a list of treatments to be used while my call is queued. Using Target object, all I have to do is just specify the treatment and its length and URS will dutifully route the call from one treatment to next until an operator opens up.
With SelectDN/Suspend combination, I found myself using IVR icon, where I define DN to be used and timeout. Timeout does not really mean much, because the strategy keeps on going...
How can I create a combination of treatments compatible with SelectDN and SuspendDN?
Marked as best answer by on Today at 11:10:48 AM
Offline tmurdach
Re: Treatment usage with SelectDN and SuspsendForDN
« Reply #1 on: January 11, 2008, 05:12:51 PM »
  • Undo Best Answer
  • I'm looking at a strategy I wrote several months ago, but never actually implemented. It was successful in testing so it might give you some ideas on solving your dilemna.
    [list]
    [li]Use [b]SelectDN[/b] in a function block to "choose" a target.[/li]
    [li]Insert a [b]Pause 2[/b] function block. This gives the strategy time (in my situation) to transfer the call to the remote Avaya switch that will be playing the treatment music[/li]
    [li]Insert an [b]IVR[/b] treatment block with your treatments. I'm only using 1 treatment block and treatment so I don't know if you can add multiple treatments in the same block, or if you need to add multiple IVR treatment blocks. My block contains a Route Point (an Avaya VDN that simply plays music and hold messaging). The DURATION of the IVR treatment is 1 second.[/li]
    [li]Next insert a [b]SuspendForDN(999)[/b] block to wait until a target is Available (for 999 seconds in this case)[/li]
    [li]Follow that step with a target block to your SelectDN/SuspsendForDN variable[/li]
    [/list]
    I will try to test some multiple treatment scenarios later today if time allows.
    « Last Edit: January 11, 2008, 09:44:22 PM by tmurdach »
