" /> 200 Second Timeout on Rockwell RoutePoint - Genesys CTI User Forum
Author Topic: 200 Second Timeout on Rockwell RoutePoint  (Read 3802 times)
Rodney
Anyone had to deal with this? If so, did you find any way around it?
ed
A route point is a Genesys term isn't it? If a call is sent to an application with a host notify ( which sends the call to the network at least on the spectrum )then why would a 200 second timeout be of issue? Is there more info?
Marked as best answer by on July 22, 2025, 02:40:00 AM
Rodney
  • Undo Best Answer
  • I.E. Using Request Host for routing instructions...Router does not find and available resource within 200 seconds.
