" /> Historical Report using CCPulse - Genesys CTI User Forum
Author Topic: Historical Report using CCPulse  (Read 6512 times)
Offline vivek
« on: January 12, 2007, 08:42:35 PM »
Our company is looking into use ccpulse for historical report.
I was wondering is there any proc and cons of this and  also I would like to know any limitations you have seen in this report?
Thanks.
Offline pdavid
Re: Historical Report using CCPulse
« Reply #1 on: January 13, 2007, 12:48:43 AM »
It's a good quick reference point, but the format is very limited. You can't export this to excel. Since we provide reports via pivot tables from digging into DATAMART from queries, they get more than enough information in a much more user friendly format. This function is disabled for all except my dept (WFM), we use it for quick hits, plus by enabling it for all, this can increase network traffic.
« Reply #2 on: January 13, 2007, 06:26:07 AM »
Yes you can, export them as HTML and then open with EXCEL.
Offline pdavid
« Reply #3 on: January 13, 2007, 04:18:15 PM »
[quote author=cavagnaro link=topic=1991.msg6705#msg6705 date=1168669567]
Really, guess you learn something new everyday - thanks for the tip, I'll be sure to give it a whirl...
MaxonMan
« Reply #4 on: January 15, 2007, 03:26:27 PM »
Hello ,
      I want to creat an historical view. But , in CC pulse+, when I right-click on an object ( an agent for example ) : The option " Create Historical View" is desabled.
      What should I do to enable this option.
Offline Adam G.
  • Still Gorgeous.......
« Reply #5 on: January 15, 2007, 05:35:04 PM »
[quote author=MaxonMan link=topic=1991.msg6713#msg6713 date=1168874787]
Hello ,
Has your CCPulse+ been configured in CME to have a connection to the ETL Service?
MaxonMan
« Reply #6 on: January 15, 2007, 05:51:21 PM »
I've juste done it , it works juste fine .
