" /> AIL option - Genesys CTI User Forum
Author Topic: AIL option  (Read 4357 times)
Maxonman
AIL option
« on: January 13, 2007, 01:14:27 AM »
      Please can anyone explain me the meaning of the AIL option :  A4400-custom-substitute-mode  ?
Best regards
Squalleo
Re: AIL option
« Reply #1 on: January 15, 2007, 04:31:04 PM »
  • What is AIL  ?
    i've done a google search, i found  that is : " Agent Interaction Layer " . No more information.
    Can anyone explain me does the AIL Server Do ?
    Offline Fra
    Re: AIL option
    « Reply #2 on: January 15, 2007, 04:54:20 PM »
  • Why Google? Better http://genesyslab.com/support/  ;)
    AIL is the core library of Agent Interaction SDK that enables you to build mainly agent desktop applications.
    Squalleo
    Re: AIL option
    « Reply #3 on: January 15, 2007, 05:00:51 PM »
  • Ah, OK .
    So genesys provide a library for Java and .net ?  true ?
    and 10x for the link  ;D
    Peter K.
    Re: AIL option
    « Reply #4 on: January 15, 2007, 05:22:52 PM »
  • Yes,
    Genesys provides a library for Java and .NET. They have a sample program you can use that comes with their Active X.
    Either access support.genesyslab.com and download it (you will need to have an account with Genesys) or ask Genesys vendor to give you a sample!
    Once you get Genesys ActiveX, we would be more than happy to help you with your coding (if any)
    Peter K.
