" /> Where does the Keyname get it's values from - Genesys CTI User Forum
Author Topic: Where does the Keyname get it's values from  (Read 3710 times)
GondiPee
Hi
anyone tell me where does colum 'KEYNAME' in 'EVDATA' get it's values from?
Gondi
  • Gondi,
    it gets is from EventData option inside CCon CME settings. You would setup it up as [type],[keyname],[type],[keyname] so that CCon would know what to save. So, if you have two attach data a and b, then you would say char,a,char,b
    I am curious, but why are you using EVDATA? I would suggest using EVREFEX instead, since it would make your life much, much easier!
