" /> Agent Desktop (Call Result) - Genesys CTI User Forum
Author Topic: Agent Desktop (Call Result)  (Read 5005 times)
Marta
« on: February 23, 2007, 12:53:10 PM »
I need to add the value "communicating this one " to the field "Call Result" .
How I can do it?
Thank you very much.
Marta
Outbound Reporting
Re: Agent Desktop (Call Result)
« Reply #1 on: February 23, 2007, 01:02:29 PM »
  • I know this one!
    If you want to add it using Desktop, try UpdateCallCompletionStats command. Do you know what I am talking about? Genesys PS told us that this is the way we can modify custom values in calling db.
    Offline Fra
    « Reply #2 on: February 23, 2007, 01:39:33 PM »
  • Marta,
    [quote author=Marta link=topic=2072.msg7119#msg7119 date=1172235190]
    How I can do it?
    CallResult is a mandatory field of the format of a calling list and must have one of the values (integer) shown in the enumeration table of Outbound Contact Reference Manual. You may be interested in adding a custom field to the format of your calling list in CME and updating it from the agent desktop with the event of type UpdateCallCompletionStats.
    Fra
    « Reply #3 on: February 23, 2007, 06:01:03 PM »
  • myPairReagendaR1.Key = "GSW_CALL_RESULT"
            myPairReagendaR1.Type = CKVTypeNum
            myPairReagendaR1.NumValue = newcallresult
            myListReagendaR1.AddHead myPairReagendaR1
    Check all the values of newcallresult on OCS Reference guide
    Marta
    « Reply #4 on: February 26, 2007, 10:25:44 AM »
  • Hello,
    I don`t want create a new field, i want to use the field "Call Result", i see in my combo this select:
    outbound.contact.callresult.unknown=Unknown
    outbound.contact.callresult.ok=Ok
    outbound.contact.callresult.abandoned=Abandoned
    outbound.contact.callresult.answer=Answer
    outbound.contact.callresult.answeringmachinedetected=Answering machine detected
    outbound.contact.callresult.busy=Busy
    outbound.contact.callresult.faxdetected=Fax detected
    outbound.contact.callresult.noanswer=No answer
    outbound.contact.callresult.pagerdetected=Pager detected
    outbound.contact.callresult.wrongparty= Wrong party
    and i need  for example:
    outbound.contact.callresult.dialerror= Dial Error
    do you know how?
    Thank you
    « Reply #5 on: February 26, 2007, 11:59:47 AM »
  • Hi, Marta,
    you want to add it to the dropdown box of your application?
    Are you talking about something like AddItem to populate your listbox?
    Actually, if someone could figure out a simple way to tie Result Causes with ComboBox value, it would be grand.
    Right now, all I could think of is something like this:
    1. define all the values in List property of ComboBox and then:
    Private Function GetCallResultBox() As Integer
        Dim out As Integer
        Select Case cbCallResult.ListIndex
            Case 0:
                out = 0
            Case 1:
                out = 6
            Case 2:
                out = 7
            Case 3:
                out = 51
            Case 4:
                out = 53
            Case Else
                cbCallResult.ListIndex = -1
            End Select
            GetCallResultBox = out
    End Function
    Private Sub UpdateCallResultBox(value As Integer)
        Select Case value
            Case 0:
                cbCallResult.ListIndex = 0
            Case 6:
                cbCallResult.ListIndex = 1
            Case 7:
                cbCallResult.ListIndex = 2
            Case 51:
                cbCallResult.ListIndex = 3
            Case 53:
                cbCallResult.ListIndex = 4
            Case Else
            End Select
    End Sub
    this is a very ugly and not nice way to do it. I wish there was a way to define a second invisible column where all the error codes would be, so then I do not have to do something this ugly...
