" /> CCPule 7.2 losing file menu - Genesys CTI User Forum
Author Topic: CCPule 7.2 losing file menu  (Read 4571 times)
Offline rellis007
« on: May 18, 2007, 08:35:09 PM »
Relatively new to CC Pulse
Using V7.2 on a XP Office
does not matter if it is an exsisting workspace or new, when i attemp to use a template ( new or old) I lose the file menu... odd.
Any ideal.
rellis007
Offline mark
Re: CCPule 7.2 losing file menu
« Reply #1 on: May 19, 2007, 12:27:57 AM »
How do you mean you lose the file menu?
« Reply #2 on: May 19, 2007, 01:40:42 AM »
Have you tried to reinstall the application?
Another computer?
Randy
« Reply #3 on: May 19, 2007, 04:49:54 AM »
I have removed and reinstalled the App,
When I say I lose the file menu,
File View Tools Window Help are the primary file meus I lose file, I only have View Tools Window & Help, if I delete teh template then the file comes back?
I initially though it was a corrupt template to perhaps corrupt thresh-hold, but happens in a new workspace as well with new templates and thresh-holds..
Rellis
« Reply #4 on: May 19, 2007, 05:56:28 AM »
Uh?? That is definitively not normal, I'll request another CCPulse installer to your provider.
Offline rellis007
« Reply #5 on: May 21, 2007, 04:29:25 PM »
Thank you :-(
Offline rellis007
« Reply #6 on: May 21, 2007, 09:32:51 PM »
FYI: I found my answer!  Seems that the un-installer for CCPulse is less than complete.
There were several things in the registry that were related to CCPulse.
After cleaning up the registry. wala, my file menu stays put.. :-)
Rellis007
« Reply #7 on: May 21, 2007, 09:44:58 PM »
Hum, still i'll ask for a new installer. just in case.
« Reply #8 on: May 28, 2007, 05:08:57 AM »
Hi, can you please tell us what version of CCP it is? 7.2.xxxx? I would hate this to happen to our users since all of us are using 7.2 right now.
thanks a lot!!!
