" /> Sip Server - CPD - Genesys CTI User Forum
Author Topic: Sip Server - CPD  (Read 15538 times)
Offline natlonehat
Sip Server - CPD
« on: September 03, 2007, 09:06:50 AM »
Hi guys,
can someone PLEASE do me a favour and put up a visio diagram of how an outbound call would work in this scenario?
Also, how do I calculate how many CPD ports I'd need for a particular number of agents?
Re: Sip Server - CPD
« Reply #1 on: September 06, 2007, 02:46:03 AM »
Hi, natlonehat,
(cool icon!!!!)
I think you need diagram for both SIP and CTI here.
Give me a day - I will put something together for you.
Best regards,
Offline natlonehat
« Reply #2 on: September 06, 2007, 02:47:11 AM »
THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU
Much appreciated victor!
« Reply #3 on: September 10, 2007, 03:59:19 AM »
I guess all that "thank you" is about my comment on the icon, right?  ;D
Ok, here is a small power point presentation (one slide really) on the signalling of Genesys and SIP when OCS is dialing out to a client and then forwards the call to the agent, by passing the queue... I paid only pre-cursory attention to the log, so I hope I got it right...
As for calculating CPDs - Genesys gives you a paper on it in the sizing guide, or something, but it really depends on how many agents you have and how long you expect them to talk, how good your calling list is and whether or not you will be doing predictive calls. It is much easier to get more CPDs later :)
Offline natlonehat
« Reply #4 on: September 10, 2007, 04:07:51 AM »
:) Hey Vic,
nah, all the thank you's were for helping me out with this.
just one last thing...the file has an odp extension....how do i open it??
;D
« Reply #5 on: September 10, 2007, 04:27:17 AM »
It's Open Office document, you can use this if do not have the suite:
http://www.officeviewers.com/
« Reply #6 on: September 10, 2007, 04:39:28 AM »
Here it is on PDF however Victor it doesn't show the CPD directly but I could understood it, can you nat?
For the CPD port you need if on Predictive for example multiply the number of agents by 1.3, so if you have 7 agents (7x1.3= 9.1) you need around 9 to 10 ports.
Offline natlonehat
« Reply #7 on: September 10, 2007, 04:54:02 AM »
To be honest, I couldnt get where CPD comes in....
I am using predictive, have 120 people on outbound and only 60 CPDs.
The records are randomly generated so we get a lot of SITs.
Appreciate the assistance...
found something for Openoffice, if it helps:
http://viewer.zoho.com/
« Last Edit: September 10, 2007, 09:46:20 AM by natlonehat »
« Reply #8 on: September 10, 2007, 06:06:24 AM »
Shouldn't be a SIT, should be a Dial Error. Which PBX do you have?
What exactly is your problem or question, maybe in that way we can help better
Offline natlonehat
« Reply #9 on: September 10, 2007, 06:13:21 AM »
[quote author=cavagnaro link=topic=2448.msg9291#msg9291 date=1189404384]
no question / issue with SIT,
just couldnt really get the CPD role in the diagram, thats all...
Really appreciate you guys taking out the time to help...
« Reply #10 on: September 10, 2007, 06:29:58 AM »
Wait,
I thought it was for for SIP server, so your CPD is actually SIP extension, so:
SIP Server? :)
Offline natlonehat
« Reply #11 on: September 10, 2007, 06:40:03 AM »
Got it vic!!
;D
[quote author=cavagnaro link=topic=2448.msg9289#msg9289 date=1189399168]
Question: why use a multiplier of 1.3?
« Reply #12 on: September 10, 2007, 07:18:27 AM »
Well we on Alcatel use this to calculate the number for dialing ports we will need asuring the worst scenario.  As predictive will overdial you will definitively need more dialing porst than agents you have. If you have less ports than agents then you will never get a real predictive dialing, neither a progressive (1 port per agent). You will have (or have) a lot of sleeping workfoce.
The question would be now who mades the dial? SIP Server? If so what are you using to the PSTN side? No real PBX? A dialogic board maybe?
Offline natlonehat
« Reply #13 on: September 10, 2007, 07:36:28 AM »
[quote author=cavagnaro link=topic=2448.msg9296#msg9296 date=1189408707]
I believe it's dialogic boards.
I have also attached a screep grab of the groups view for one of the campaigns we run.
Hope it gives you a better idea...
« Reply #14 on: September 10, 2007, 07:39:07 AM »
But do you have some sort of PBX? Nortel, Avaya, Alcatel, Cisco, etc?
