" /> Is there an option in CME to predefine skill level - Genesys CTI User Forum
Author Topic: Is there an option in CME to predefine skill level  (Read 2899 times)
kjanev
« on: April 04, 2008, 01:38:29 PM »
Hi all,
when moving agents from one working segment to another, the supervisors should select desired skills and skill level. The skill level in our case is always the same - 10. So I am wondering if there is an option to skip selecting skill level or an option to predefine it from now on to same value -10. 10Q in advance. :)
Marked as best answer by on Today at 05:46:21 PM
tony
Re: Is there an option in CME to predefine skill level
« Reply #1 on: April 04, 2008, 01:46:48 PM »
  • Undo Best Answer
  • I'm on a roll, today.... :)
    I believe it is possible to apply automation scripts when adding an Agent to an Agent Group, to ensure they have the right Skills applied but I do not believe that that is standard in the CME Application.
    I do not believe there are any standard settings which can be applied to ensure an Agent is given the right Skill level, for any Skill applied within CME.
    You can apply a blanket update to various Object Types using the "Multiple Objects Update Wizard" in later versions of CME, which might help you...
    Tony
