" /> GVP outbound and Alcatel-Lucent OXE - Genesys CTI User Forum
Author Topic: GVP outbound and Alcatel-Lucent OXE  (Read 10917 times)
Offline aflores
« on: May 10, 2008, 05:36:27 PM »
Hi.
, or
I have a trouble. GVP inbound integrated via SIP Trunking with OXE is working ok. But also need to use the Outbound but Alcatel says that this feature is not validated so alcatel did not give technical support for Outbound integration with Genesys.
At this time the outbound is not working and I have to make it work, so if anybody have any kind of information that can help me to make it work I will appreciated.
Also any idea, no matter if it is not with oxe, something that can help me.
thanks
AFLORES
Re: GVP outbound and Alcatel-Lucent OXE
« Reply #1 on: May 10, 2008, 06:51:27 PM »
What is exactly the problem you are having? If you already can receive calls on OBN application declare the Outbound SIP Proxy (logical IP address of OXE/sipdict -l Ip address) and configuring the public network category of the SIP Trunk Group should do it.
Offline aflores
« Reply #2 on: May 11, 2008, 01:06:28 PM »
Hi cavagnaro, the problem is that since the GVP the external calls doesn´t work.
We can not do externals calls.
The picture is this: The OXE and the GVP are connected via SIP trunking. Also the OXE have E1 (PCM-R2) to make external calls.
What we want to do is the GVP make externals calls trought the E1 of the oxe, and it is not working.
So the GVP have to take SIP trunk group and them E1 trunk group to make the external calls.
Thanks for your reply.
Any other idea will be well receive.
Tomorrow, I will try what you say and let you know the results.
regards
AFLORES
Offline aflores
« Reply #3 on: May 11, 2008, 01:22:24 PM »
Another question:
When you says:  "declare the Outbound SIP Proxy (logical IP address of OXE/sipdict -l Ip address)";  you mean that I have to declare on the GVP configuration the OXE as Outbound proxy?
I´m not the GVP technician, Im OXE technician. So I dont know to much about GVP, so I want to no what to do on GVP to explain to my partner who is in charge of GVP.
Thanks again.
AFLORES
« Reply #4 on: May 11, 2008, 04:26:55 PM »
??? Well yes, GVP must know how to reach OXE. On GVP you will need then to declare the outgoing number as 012345678 where 0 is an ARS or a Professional Trunk Group Seizure.
I will recommend you to read the documentation of GVP.
I also found very difficult that Genesys says they do not support the OXE integration or Alcatel saying that they do not support Genesys...from where you get this info?
Offline aflores
« Reply #5 on: May 11, 2008, 11:35:50 PM »
Hello again.
I work in Venezuela for an Alcatel-Lucent BP Premium. Im in charge of the OXE plataform. Im Alcatel Oxe ACSE (but never have work in an integration with GVP). I opened on Alcatel-Lucent technical Support center a Service Request and the answer was that. Since the GVP Outbound have not been tested yet, Alcatel did not give us technical support on this issue, so they just close the Service request.
We, may be erronously were thinking that, if GVP Inbound trought SIP is working and tested, the Outbound was working and validated too, but is not shus as, so, as I say, Alcatel did not give us technical support.
thatks for your help.
Tomorrow I will chek everything you suggest and will let you know the result.
Any other idea, well recieve.
By the way, we have not talk to Genesys yet.
Regards
AFLORES.
« Reply #6 on: May 12, 2008, 01:04:04 AM »
So you work for anew eBD :D Do you know Marita? I work for eBD Peru.
Abre el caso con Genesys mejor, te van a dar un mejor soporte que el de Alcatel...
Offline aflores
« Reply #7 on: May 12, 2008, 01:10:59 AM »
;D Saludos
Efectivamente trabajo para Anew eBD
Mi nombre es Alberto Flores.
No hay ninguna Marita en Anew, creo que te refieres a Marinelly Tovar.
Marynelly, tiene ya tres años que se fue a España, contratada por NextiraOne. Aun estamos en contacto con ella.
Gracias por tu ayuda.
Le dire a mi compañera que maneja el GVP que abra el caso de soporte con Genesys.
Saludos Cordiales.
Alberto Flores
aflores@anew.com.ve
albertoflores28@hotmail.com
« Reply #8 on: May 12, 2008, 01:22:07 AM »
Hum, y Nelson sigue trabajando con ustedes? Era Maria entonces? Llevé un curso de estadísticas de Genesys con ella allá en Caracas hace como un año y medio. Mi nombre es Jorge Cornejo.
También te respondí en el foro de alcatel...
« Last Edit: May 12, 2008, 01:26:18 AM by cavagnaro »
Offline aflores
« Reply #9 on: May 12, 2008, 03:33:44 PM »
Hola Jorge. Creo entonces que te refieres a Maria Trovato. Si, ella continua con nosotros, te manda saludos.
Nelson no esta con nostros desde hace tiempo ya. Esta trabajando para Telefonica Venezuela.
Te comento que efectivamente el problema estaba en la Categoria Publica del Grupo troncal. Por defecto, al declarar el grupo troncal SIP, le coloca 18. La categoria Publica 18 no tiene permisologia de marcar nada.
Le cambiamos la categoria publica al grupo, a 5, que tiene permisologia de todo y funciono perfectamente.
Muchisimas gracias por tu ayuda.
Si en algo re podemos ayudar por aca, en algun momento, no dudes en contactarnos.
Atte.
Alberto Flores
« Reply #10 on: May 12, 2008, 05:22:36 PM »
;D Si ella! mandale mis saludos también por favor, muy chevere ella.
Que bien que se haya solucionado el problema, los de Alcatel India a veces son muy duros o fue Jean?
