" /> migrating genesys framework - Genesys CTI User Forum
Author Topic: migrating genesys framework  (Read 4440 times)
Offline Glenn
« on: June 25, 2008, 11:27:09 AM »
If I want to migrate genesys framework from one server to another (so changing hardware), what is the best way to do this?  The versions of all applications remain the same and the DB stays on the server as it is right now.
Can I use the migration wizard or should I install everything manually.  Does anybody have tips or things I should know before starting?
What comes up in my mind is confserv.  I thought this name was sort of fixed, so how can I be sure that after the server migration, everything will still work?
Glenn
Offline thicke
Re: migrating genesys framework
« Reply #1 on: June 25, 2008, 01:06:29 PM »
Is this on UNIX, or Windows?
Offline CTIgem
« Reply #2 on: June 25, 2008, 01:16:34 PM »
You have install dbserver and config server, that's your base.
After that run the install for each app, it'll prompt you to install new app or select existing app.
Select existing app and that should be it.
Offline Glenn
« Reply #3 on: June 26, 2008, 07:39:30 AM »
[quote author=thicke link=topic=3091.msg12547#msg12547 date=1214399189]
It is on windows.
Only the framework should be migrated (and relocated), so the IP address will change.  The servers include Framework, Reporting, MCR and WFM.
Telephony has been updated earlier, but I don't know if this will still work if I move my framework to other servers...
Offline CTIgem
« Reply #4 on: June 26, 2008, 12:25:56 PM »
Should stay away from changing IP address. It gets messy. You have to disconnect all the connections.
What I do is, build up server, bring down old server and bring in new server with same IP.
Then install dbserver and config server, connect to your db engine.
Then install whatever you need.
Offline Glenn
« Reply #5 on: June 27, 2008, 07:19:13 AM »
[quote author=CTIgem link=topic=3091.msg12561#msg12561 date=1214483156]
well, the problem that I cannot take the decision to do that.  I just follow instructions and I doubt that the decision makers know what it means if I need to change everything.
It looks messy to me too, that's why I wanted to know if somebody here had done the same and how to deal with it...
