" /> RecordProcessed not updating database - Genesys CTI User Forum
Author Topic: RecordProcessed not updating database  (Read 13119 times)
Pierre Blanchet
« on: October 16, 2008, 02:51:45 PM »
I tried to call the 'RecordProcessed' after updating userdata to be sure to save info within the database...but nothing is updated. The OCS log give me that. "EventAttachedDataChanged is ignored. Reason: agent is not in BusySeized or BusyRinging status". I don't understand what is wrong. What is supposed to be the state of the agent to update info?
Thanks for your help
Pierre
10:16:33.240 Trc 50002 TEvent: EventAttachedDataChanged
Agent Info - Status: AGENT_BUSY_OUTBOUND, Background Status: AGENT_READY, BusyType: 3, BusyType Duration: 3, PersonDBID: 110
Place - 2200_7506, PlaceDBID: 225
Position DNs: Number: 2200, SwitchDBID: 101, State: OffHook, Service: In
Extension DNs: None
Logins: AgentID: 5556, Queue: 3000, DN: 2200, SwitchDBID: 101
Groups: Campagne_02, GroupDBID: 130
Calls: ConnID: 0066019ee3775077, Type: 3, RecID: 81
CallRecords: RecID: 81, Type: 1, Campaign: Campagne_02, CallList: Telephonie_SDD, ChainID: 4, ChainN: 0
received from 65200(--)LNAP29PD:3000(fd=424) message EventAttachedDataChanged
AttributeCallType 3
AttributeCallID 26869796
AttributeConnID 0066019ee3775077
AttributeCallUUID 'BRDB0KD4NP4ST57ICNB0RCRHNO0000E3'
AttributeUserData [677] 00 18 01 00..
AttributeCustomerID 'Resources'
AttributeThisDN '2200'
AttributeThisDNRole 2
AttributeThirdPartyDN '2200'
AttributeTimeinSecs 1224166593 (10:16:33)
AttributeTimeinuSecs 303000
AttributeEventSequenceNumber 0000000000000b59
Print GSW UserData:
GSW_TZ_OFFSET -14400
GSW_CHAIN_ID 4
GSW_CALLING_LIST 'Telephonie_SDD'
GSW_ATTEMPTS 10
GSW_CALL_RESULT 0
GSW_CALL_ATTEMPT_GUID 'C6B7C710-4A61-4DD9-B2C9-C7385331D3CF'
GSW_PHONE '94181111111'
GSW_CALLBACK_TYPE 'Campaign'
GSW_DATE_TIME '10/15/2008 17:00'
GSW_AGENT_REQ_TYPE 'RecordProcessed'
GSW_APPLICATION_ID 110
GSW_CALLING_LIST2 'Telephonie_SDD'
GSW_CAMPAIGN_NAME 'Campagne_02'
GSW_RECORD_HANDLE 81
GSW_TREATMENT 'RecordTreatCampaign'
10:16:33.303 Trc 50002 TEvent: EventAttachedDataChanged
Extension DNs: None
received from 65200(--)LNAP29PD:3000(fd=424) message EventReleased
AttributeAgentID '5556'
AttributeCallState 0
AttributeThisQueue '3000'
AttributeCallType 3
AttributeExtensions [41] 00 02 00 00..
'OrigAddress' '2008'
'OrigAddrType' bin: 00 08
AttributeThisTrunk 3275
AttributeOtherTrunk 5524
AttributeOtherDNRole 2
AttributeOtherDN '94189339765'
AttributeTimeinSecs 1224166599 (10:16:39)
AttributeTimeinuSecs 334000
AttributeEventSequenceNumber 0000000000000b5a
Print GSW UserData:
GSW_CHAIN_ID 4
GSW_ATTEMPTS 10
GSW_CALL_RESULT 0
Offline Fra
Re: RecordProcessed not updating database
« Reply #1 on: October 16, 2008, 03:14:21 PM »
Hello Pierre,
as it was said in other threads, you haven't used any RecordProcessed, at least from the excerpt you posted: issueing a request to update attached data is NOT and has nothing to do with processing a record. In order to update user fields and have OCS store the record in the db you must use UpdateCallCompletionStats and RecordProcessed requests.
Fra
Pierre Blanchet
« Reply #2 on: October 16, 2008, 05:24:53 PM »
Here is a larger view of the log...as you can see, I've sent in order a 'UpdateCallCompletionStats', then a 'ScheduledRecordReschedule' and finally a 'RecordProcessed'. For all of them, I always received the same error in OCS log as
Any idea?
10:16:32.990 Trc 31003 Call info: ID 81, GCTI state 33, CM state 9, Time 0, Dialer ID 108, Switch ID 101, DN ID 548, Agent ID ; Record process flag 1
Set CallResult: 33 to CallData with RecID: 81
CPDServerMessage: Rsp_ChannelsReleased
             IAttr_CallStatus No status
              IAttr_ErrorCode No error
            IATRCFG_REQUESTID 161
             BAttr_Extensions
'GSW_DialingChannels' 1
ReleaseChannel - Number of Free Channels: 12. Total number of Channels: 12.
AttributeCallType 3
AttributeUserData [550] 00 14 01 00..
AttributeTimeinuSecs 162000
AttributeEventSequenceNumber 0000000000000b57
Print GSW UserData:
GSW_CHAIN_ID 4
GSW_ATTEMPTS 10
GSW_CALL_RESULT 0
GSW_AGENT_REQ_TYPE 'UpdateCallCompletionStats'
10:16:33.162 Trc 50002 TEvent: EventAttachedDataChanged
Extension DNs: None
AttributeCallType 3
AttributeUserData [614] 00 16 01 00..
AttributeTimeinuSecs 240000
AttributeEventSequenceNumber 0000000000000b58
Print GSW UserData:
GSW_CHAIN_ID 4
GSW_ATTEMPTS 10
GSW_CALL_RESULT 0
GSW_AGENT_REQ_TYPE 'ScheduledRecordReschedule'
Extension DNs: None
AttributeCallType 3
Print GSW UserData:
GSW_CHAIN_ID 4
GSW_ATTEMPTS 10
GSW_CALL_RESULT 0
Extension DNs: None
AttributeCallType 3
Print GSW UserData:
GSW_CHAIN_ID 4
GSW_ATTEMPTS 10
GSW_CALL_RESULT 0
« Reply #3 on: October 16, 2008, 05:28:06 PM »
What is the status of the agent while doing these requests? Agent MUST be on conversation or in Wrapup, right?
Pierre Blanchet
« Reply #4 on: October 16, 2008, 05:51:33 PM »
Agent status is not ready and is still on conversation. In fact I've test both and I received the same message. In TServer log, everything looks right. No error logged for TServer and the client received no error...but the update is not done in database.
Offline Fra
« Reply #5 on: October 17, 2008, 09:29:36 AM »
I can't see any "EventUserEvent" of type UpdatecallCompletionStats, RecordReschedule and RecordProcessed, just "EventAttachedDataChanged" that is the ack to "RequestUpdateUserData".
Pierre Blanchet
« Reply #6 on: October 17, 2008, 01:10:12 PM »
How can I send the "EventUserEvent"?
I can't find any exemple of sending an "RecordProcesses" to the server other than this:
KeyValueCollection keyValueCollection3 = new KeyValueCollection();
keyValueCollection3.Add("GSW_AGENT_REQ_TYPE", "RecordProcessed");
keyValueCollection3.Add("GSW_APPLICATION_ID", appId);
keyValueCollection3.Add("GSW_CALLING_LIST2", "Telephonie_SDD");
keyValueCollection3.Add("GSW_CAMPAIGN_NAME", campName);
keyValueCollection3.Add("GSW_RECORD_HANDLE", handle);
keyValueCollection3.Add("GSW_TREATMENT", "RecordTreatCampaign");
requestUpdateUserData3 = Genesyslab.Platform.Voice.Protocols.TServer.Requests.Userdata.RequestUpdateUserData.Create(thisDn, connId, keyValueCollection3);
response = tServerProtocol.Request(requestUpdateUserData3);
Offline Fra
« Reply #7 on: October 17, 2008, 01:35:29 PM »
I'm not a developer, but I'm sure that our brazilian  ;D Cavagnaro or Vic can easily help you out  ;D
« Reply #8 on: October 17, 2008, 03:08:37 PM »
::) oich this dogs are less smart on this days lol
Set myEventInfo = CreateObject("DesktopToolkitX.TEventInfo")
Set myListReagendaR = CreateObject("TCommObj.CTKVList")
Set myPairReagendaR = CreateObject("TCommObj.CTKVPair")
    myPairReagendaR.Key = "GSW_AGENT_REQ_TYPE"
    myPairReagendaR.Type = CKVTypeString
    myPairReagendaR.StringValue = "RecordReschedule"
    myListReagendaR.AddHead myPairReagendaR
    myPairReagendaR.Key = "GSW_CAMPAIGN_NAME"
    myPairReagendaR.StringValue = Campaign_Name
    myPairReagendaR.Key = "GSW_APPLICATION_ID"
    myPairReagendaR.Type = CKVTypeNum
    myPairReagendaR.NumValue = AppId
    myPairReagendaR.Key = "GSW_RECORD_HANDLE"
    myPairReagendaR.NumValue = Record_Handle
    myPairReagendaR.Key = "GSW_DATE_TIME"
    myPairReagendaR.StringValue = Date_Time_Us
    myPairReagendaR.Key = "GSW_CALLBACK_TYPE"
    '0=Personal, 1=Campaign
    Select Case iCallBackType
        Case 0:
        CallBackTypE = "Campaign"
        Case 1:
        CallBackTypE = "Personal"
        Case Else:
    End Select
    myPairReagendaR.StringValue = CallBackTypE
    myPairReagendaR.Key = "ProcesoRescheduleCTI"
    myPairReagendaR.StringValue = "Lanzado Exito"
    Set myEventInfo.UserData = myListReagendaR
    myEventInfo.ThisDN = frmSender.TExtension1.TDN
    frmSender.TExtension1.TSendUserEvent myEventInfo
    Set myEventInfo = Nothing
    Set myListReagendaR = Nothing
    Set myPairReagendaR = Nothing
Pierre Blanchet
« Reply #9 on: October 17, 2008, 03:18:51 PM »
your exemple is base on the VB6 OCX. I use the .Net SDK 7.6 and I don't have the DesktopToolkitX object. I need exemple with the new .Net DSK. Am I correct when I said the DesktopToolkitX is the OCX version?
Pierre
« Reply #10 on: October 17, 2008, 03:35:08 PM »
Er...I'm just playing with .Net SDK...sorry
Pierre Blanchet
« Reply #11 on: October 17, 2008, 05:20:24 PM »
You said that you don't use the .Net SDK or you said that you only use the .Net SDK?
Cause if you use the .Net SDK, you may have the answer of my questions!
« Reply #12 on: October 17, 2008, 05:32:54 PM »
Oh sorry for not being concrete. What I ment was that as you, Im starting with .Net SDK, I'm a user of VB ActiveX, however still a little bit lost on C#...
Marked as best answer by on Today at 06:07:22 AM
Pierre Blanchet
« Reply #13 on: October 17, 2008, 06:21:17 PM »
  • Undo Best Answer
  • OK thanks. I think I'am close to the solution but I cannot find good exemples.
    I hope someone else will find.
    Offline Luk
    « Reply #14 on: October 20, 2008, 01:53:27 PM »
    hi,
    From what I read, you are building your own softphone in .NET.
    What are you trying to achieve? Do you have some custom fields and do you want to change (or set) the value of these fields in the calling list? Or do you want to change values of mandatory fields?
    I've done this with Genesys Agent Desktop 7.6 using Java. What I learned is that there is more required than just updating the attached data!! In Java you need to use OutboundService, OutboundChain and OutboundRecord interfaces. I would suggest you look for similar interfaces in the .NET API.
    In Java there are 2 methods that can change the record in the database of which one does an update as well. Keep in mind to do update as well.
    Hope it helps :-s
    Luk.
