" /> different statistics in DMA and StatServer - Genesys CTI User Forum
Author Topic: different statistics in DMA and StatServer  (Read 3202 times)
PJ
« on: October 26, 2008, 11:59:07 AM »
can someone please tell me if it is normal to have different definitions in StatServer and DMA for the same statistics?
PJ
tony
Re: different statistics in DMA and StatServer
« Reply #1 on: October 26, 2008, 04:44:18 PM »
  • No - it is not normal.  Usually (depending on version) a synchronization takes place between the StatServer and DMA.  Unless you are running another StatServer (for another reason - CCPulse+/Routing, etc.) - then it is possible that they may be different.
    What, specifically, is the problem?
    Tony
    « Reply #2 on: October 26, 2008, 08:45:22 PM »
  • As Tony says be sure you are looking at the right StatServer
