" /> Default call result in GAD Outbound - Genesys CTI User Forum
Author Topic: Default call result in GAD Outbound  (Read 4574 times)
Offline Dale
« on: March 10, 2009, 10:05:55 AM »
Guys,
In our outbound contact solution, we have the canned call results, and some custom ones...
The default, when an advisor requets a record from the list via GAD, is 'Unknown Call Result'.
Can this be changed?
Also, any idea's on how to overcome the GAD 'timing out'? ie, if an advisor disconnects a call, they have to select a call result and hit marked done in 5 minutes...
Dale
Re: Default call result in GAD Outbound
« Reply #1 on: March 10, 2009, 03:07:48 PM »
Yes, the agent can select a Call Result and set it up.
Offline Dale
« Reply #2 on: March 10, 2009, 03:42:58 PM »
i know they can manually amend it and choose one, but im after setting the default value before they do anything, when they go into a new record...
« Reply #3 on: March 10, 2009, 03:49:10 PM »
When you insert a record (via SQL or via AddRecord API) you can also stablish the value you want for that field.
Offline Dale
« Reply #4 on: March 10, 2009, 04:36:32 PM »
Thanks...
So this would require some heavy customisation then?
« Reply #5 on: March 10, 2009, 04:37:51 PM »
Depends on how you insert your records to BD, if by SQL directly then not too much work. If by API then a little more but not that much.
